380hp
and its making 306rwhp on 18psi with a lack of timing
tuner said it will easily make 320+ on only 18psi, just need to fix the miss :)
Will be interesting to see what you can get out of then. If you are able to get 250-260rwkws (340-350rwhp) out of it and still have good bottom end...then yeh the theory with the manifold will be taking a beating. :D
Hi Guys
My HKS cast manifold is of at afe being flow tested at the moment will post results when I get it back though he still recons that will be a couple of weeks 4 months of the road and counting damn it
Cheers Peter
just had some more work done on my 20 this week
put an external gate out the back of my td-06 17c which was internal gate, big new breather tank set up and bigger pod, and profec b spec2
went 357.5rwhp at 19psi
on standard exh mani
and no head or bottom end work for now
i did not think an rb20 was capable of this
Ah, bored in a hotel room waiting for this afternoons drinking session, er i mean Hurling Grand Final...so
TD06-20G
Here is the Mitsubishi version of my compressor , then the 17C
TD06-17C
Are you sure you have a TD06-17C. You seem to be making more power then the compressor map suggests possible. Even allowing for differences in MHI vs Trust turbos
yeh the 17c has a rating of 400hp in internal form, i made 280hp before converting also at 19psi and full boost was at around 4000rpm. but the tune wasnt as good.
mods are:
gts4rb20
gtr injectors
ems stinger
td06 with tial copy gate
cooler, big breather
pretty small budget, biggest gains were had with opening up the back of the turbo and fitting a big pod. all of this is in an s13 silvia aswell, will post graph soon
you made 77rwhp from a tune and changing from blocking the actuator and controlling boost via a bigger external wastegate, at the same boost?
if so, im going to get gate...
Edited by Cerbera
from what research ive done on line it seems that using an external gate and routing it out to atmosphere will actualy allow for hp gains.
i know some one on a supra forum was tired of the noise of the external gate and rerouted it and found on the dyno he had lost 30whp simply by rerouteing the gate into the exhaust.
and its not unusual to gain silly hp via a proper tune, local shop here fuel tuned a blown mustang and made 550whp, not shabby, but when they went back and did some ignition tuning it jumped to a hair over 700whp.
For all you boat anchor lovers
http://www.skylinesaustralia.com/forums/in...howtopic=103095
Ha ha ha nothing wrong with the old boat anchor :( , thanks mate :P
hey i just have a quick question, and im hoping someone can answer for me, i have a bosch 019 intank pump at the moment, which i am maxing out, can someone tell me the next 2 sized up bosch pump that are intank please? plus flow rates aswell if possible. i want an intank pump, not external.
thanks in advance
chris
Meh dont know unless i look up some info i have at home...but my 2c, dont need to
Get a new Bosch 040. They are cheap new, and flow more then a GTR pump, and fit easilt in the std cradle with a 30min tweak.Installation is a DIY 90 min job. If you want to set up a fulltime power supply and relay it takes a bit longer :)
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
