HOLY BRAIN STRAIN BATMAN :D:D
Well that was informative while at the same time headache forming.
Anyway, I just recently sold my 91 240sx SE that of course had Super HICAS. After looking carefully at the wiring diagram for the car I found that all I had to do was remove a fuse (from the panel inside the car, driver's side) marked ELECTRONICS to disable the HICAS system. That locked it up, straight just as Nissan states, and had no further issues.
Now from what I've "heard" the Skylines use a better system but the premiss should still be the same as it's electronically controlled. Disable the system and it'll lock. So I'm gona try this option first and if it does'nt work out properly, I will look in to one of the bars being offered. I'd just really like a clear cut, no nonsense, step by step install (with pic's) for a GTS-t. Anyone willing to post up on this?
Thanks guys.
Cheers B)
  • 4 weeks later...
  • 2 months later...
  • 2 months later...
  • 3 weeks later...
Installed my lock bar today, went in pretty easy, very happy with it, doing the wheel alignment tomorrow morning.
thanks geoff, great product and from seeing 8 pages to this thread...plenty of support to anyone having troubles.
I'll be using my car for the drift training day this weekend so should make it easier to do massive dori dori circles!!!
cheers
abcent, glad you like. Hope the dorifto is good too.
Jon, slowly producing but the back has spat the dummy so I can't walk right now (lose the use of my left leg due to disc rupture crimping the nerve). usually takes a few days to sort out but I have plenty of stock to get bars out withing a week of ordering. Cheers.
TO HICAS OR NOT TO HICAS THAT IS THE QUESTION. OK. let me get this straight,if i replace the HICAS rack in a R33 GTR with
a HICAS LOCK BAR.
1. Will i loose power assist to the front wheels at low/parking speeds but it
will feel the same at higher speeds?
2. Will the HICAS warning light come on/stay on and require the warning light
bulb to be removed?
3. Which FEELS better for street driving HICAS OR LOCKED?
does anyone know the answers to this question ?
I thought this had been answered many times across the forum but:
1. No you won't lose power steer, it simply reverts to the slightly harder setting. Noticeable when cranking around a roundabout at about 50kmh. Fitting a set of castor adjustors in my case completely removed the effect and improved turn in dramatically.
2. Yes.
3. It depends. Some people shouldn't have a license and probably can't tell if the front or rear wheels do the steering on their car. Just about everyone else will get some benefit. If you ever get some oversteer at over 80 kmh (and it can happen even if not hooning, I came around a bend where some tool had tracked mud onto the road and had a brief moment in the GTR) you will find the rears turn in the direction of the slide creating a tank slapper effect. This has resulted in numerous loss of control situations.
Hope that helps.
  • 4 weeks later...
Next you need to remove the lock wiring on the rubber boots at each end, pull back the boots and then "crack off" the large 4 sided rod end so they are easier to remove later.
"crack off" is a term mechanics use to break the initial resistance a nut or bolt has. These are threaded but you may need a large mallet or bar to help if you aren't strong enough to get them to move.
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
