im about to chuck my lock bar in this weekend. i have done a lock on a 32 and it was locked on my old 33 as the hicas was faulty but i must admit i never new there was a computer in the boot that controlled the 4 wheel steer.
i knew that the hicas in r33 was electronic as opposed to the hydraulic set up in the r32 skylines but yer the computer is news to me.
i have recently pulled the hicas sensor off the steering collumn when i did a steering wheel change and only thing i can notice is the light come on when i turn hard if im dring over 80!
i guess i have 3 main questions ..
1. will removal of the disc sensor set-up interfere with my power steering???
2. will unplugging the electronic clips on the hicas interfere with my power steering?
3. will removing the ecu in the parcel shelf interfere with my power steering??
i want my steering to feel just the same as stock but with out the rear wheel steer.
You need a HICAS Bosskit for your steering wheel,
Leave the computer alone and it will be fine.
The only thing you remove is the bar itself and the bulb. Leave EVERYTHING else or you will have problems.
  • 1 month later...
what about removing the fuse?? where is the fuse located for the hicas? i read somewhere that its in the boot, but where in the boot? i have just put a lockbar in and it made so much difference to the handling of the car. i like i like.
  • 4 months later...
i took my hicas ecu out years ago in R33 GTSt. i guess u could say the steering was slightly heavier but im also running 19" rims which weigh shitloads more than the stockers.
i also never had the hicas light come up on the dash when i removed the ecu
some ppl think its weird but it was basically unplug it all and things were normal.
ben...
Has anyone tried an RB25 PS pump in a 32 GTR rather than gutting the rear impeller? Has any one removed all the wiring from the rear (the disconnected bits) to free up some weight/clean up? Were upgrades to the caster bits necessary?
  • 1 month later...
Just tape them up and cable tie away nicely.. Or, if you CBF i think you can pull them up into the boot through the big ass grommet there.
Hi guys, i have recently bought a R33 with the HICAS motor being removed, and it's got a lock bar installed.
The steering feel is stiff when car is not moving, for e.g. when trying to do a reverse parking. When driving the car at higher speeds, its still stiffer than a stock R33 with the HICAS unit.
What I would like to know is, does the removal of the HICAS unit and the installing of a lock bar caused the power steering to be stiff ? I know the removal of the HICAS unit is to prevent the rear wheels from steering and the HICAS lock bar is obviously to lock the rear wheels into a locked position. But does this naturally mean the steering should be stiff ?
Or is there a problem with the power steering unit or pump ?
Is it possible to have the HICAS unit removed + installing the lock bar, BUT still retain the feeling of a power-assisted steering ?
I am totally not used to driving this car with the stiff steering, and would like to return to the original feeling of the normal power assisted steering. I asked the previous owner why the steering was so stiff, and he told me that its because the HICAS unit has been removed. Is that really the reason behind it?
Hope you guys can help out here as I am really new but I have searched through the forums on this topic but cant seem to find out the exact answers. Thanks guys !
Edited by Brabus
Hey dude,
Check in the boot and see if the HICAS ECU is still there and plugged in.
Fitting mine the steering didnt change at all. But i hear that if you remove the ECU, then it will go heavy.
so many variations with this hicas lol... i removed my hicas computer years ago when doing a boot install, the light never came on, the steering was light as usual i also got 19's with 245/265s on. recently i finally got around to fitting my lock bar. and again no issues at all.
Ben...
  • 1 month later...
what about the steering position sensor in the r33? located behind the steering wheel / boss kit. its the round disc with the tab that fits through the slot in hicas specific boss kits / standard wheel.
it was mentioned above that once removed, it had no bearing on power steering weight, etc.
can i get a confirmation or otherwise about removing this sensor?
Edited by Munkyb0y
  • 4 months later...
hey, awesome write up...plan on installing the bar in the next week or so. Was just wondering with the wheel alignment, would you be able to do it yourself? maybe with some string? lol i know it sounds dodgy but might not have time to drive it to a w/a place for a few days...
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must me missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
