  • 5 months later...
everyone is going about removing the HICAS what is the main benefit of removing it maybe a noob question but ive read the 300ZX sites and some of the people on there like it and they have reached the 20yr old mark.
Edited by B-rice
  • 3 weeks later...
hi, am in the middle of removing the hicas unit behind the diff, how exactly do u " crackoff" the rod ends which connect to the unit. thanks
exactly my thoughts, how to do this??
have you done yours?
breaker bar with these kinda tool attached? (http://imgur.com/sUJ7i)
  • 2 months later...
I hate to revive an old thread, but I will be fitting a HICAS lock bar to my S1 R33 GTST.
The instructions on page 1 seem a little outdated given the comments in the rest of the thread, alot of people are doing alot of different things about the power steering lines etc.
Has anybody done on a 33 recently, what did you do and were you happy with the outcome ?
Attempted this last night with not alot of success. I couldn't "crack" the 4 sided rod out of the HICAS unit . The HICAS bar I brought still has the arms in it , now I know why !
It's going to need persuasion of the vice kind I reckon ! . So I thought seeing my bar had arms already , that I would just remove the HICAS system as one whole unit .
Well that didn't happen because one of the nuts was rusted shut , it started to round off which is when I stopped . Put my HICAS back in , cracked a beer and called it a day .
Thinks I might just get a workshop to put it in and wheel align at the same time .
It seems what should have been a simple job ended up being a pain in my arse .
Can anybody in Adelaide recommend a workshop that is happy to put a HICAS lock bar in with wheel alignment without robbing me ?
  • 3 weeks later...
I just tried to remove mine and... i have a 3 and a half inch exhaust on my 34 GTR, so could not get the the right hand side, and could not crack off the arms -_- to a mechanic tomorrow to do it, dont have the tools i need to do it correctly fml
  • 2 months later...
has anyone here ever had issues with the arms coming loose after they have installed the HICAS lock bar?
I had my wheels aligned after installing coilovers and the car didnt feel right, but i couldnt figure out what it was. then i was driving it the other day and the rear rod that connects to the lock bar came out of the lock bar :/
had a look underneath the car for the first time today since and noticed the other side was loose as well. has anyone had this issue? i did them up bloody tight when i first installed it.
  • 2 months later...
  • 2 months later...
No. It might take a bit of load off the tie rod end when you're undoing it but it won't cause any dramas doing it jacked up.
However in saying that, most suspension components should be tightened up with the car sitting as close to normal ride height as possible (wheels/suspension carrying the load). It's more of an issue with rubber bushes as they will twist and bind up a bit if you fully tighten them before lowering the car onto the wheels. You should assemble the parts with the bolts loosely tightened then lower the car onto blocks under the wheels or put the jack stands under the rear arms so the suspension is bearing the load (this is done so you can still get under the car!) and then tighten everything up to the correct torque. Drop it down onto the ground and should be all good.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
