Gday Fellars
Wrecking a sI r33 gtst. The car has been well maintained, with 90000 ks on the clock.
All running bits are available and undamaged. That is, engine, turbo, box, radiator, etc. full brake set in excellent condition.
All interior is available and in excellent condition.
For the exterior:
The bonnet is bent, but repairable - offers
right guard
right door
right rear 1/4 panel
boot lid with sII spoiler
rear bar
roof skin
The shell itself is rolling, and it is in pretty good condition. The insurance company just decided to write it off, because it is an import and too much trouble to source the parts etc. and also, the chasis is slightly bent. Perfect for a drag or track car buildup. reasonable offers
Anything not mentioned as sold is available, like I said, the whole car is still here. I'll write down parts as I sell them, so If they're not written down, I still have them
Stuff sold so far
Anything any of you need, just ask, In regards to price, my price range is just the price that this stuff normally goes for,
PLEASE CONTACT ME VIA PHONE - 0422 082 770 (IAN). DO NOT REPLY VIA PM
https://www.sau.com.au/forums/topic/58805-wrecking-si-r33-gtst/
- dash surround plastic with all attachments ( bottons, clips, clock, vents ,coin holders etc etc )
- gear stick plastic surround including ash tray
- drivers side plastic arm rest with window/ door control switches
can you send me pic's and prices to : [email protected]
cheers
ron
pm me on price of these please
1: the dash surround around clock hazard switch that goes down around the stereo. without swithes.
2: both sunvisors
3: standard steering wheel
also pmd you
hey mate, interested in, 5spd gearbox, flywheel, tailshaft, clutch, pedal box, slave cylinder, mater cylinder and pressure plate, how much and wat condition?? thanks
Hey
do you have this plastic panel section that clips on under the steering wheel under the dash? it has about 5 clips that hold it on, they snap easily, is this part available with all clips intact? See image attached.
Also the drivers side a-pillar, is this available, without any holes drilled in it or clips missing?
cheers,
Chris.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
