Gday Fellars
Wrecking a sI r33 gtst. The car has been well maintained, with 90000 ks on the clock.
All running bits are available and undamaged. That is, engine, turbo, box, radiator, etc. full brake set in excellent condition.
All interior is available and in excellent condition.
For the exterior:
The bonnet is bent, but repairable - offers
right guard
right door
right rear 1/4 panel
boot lid with sII spoiler
rear bar
roof skin
The shell itself is rolling, and it is in pretty good condition. The insurance company just decided to write it off, because it is an import and too much trouble to source the parts etc. and also, the chasis is slightly bent. Perfect for a drag or track car buildup. reasonable offers
Anything not mentioned as sold is available, like I said, the whole car is still here. I'll write down parts as I sell them, so If they're not written down, I still have them
Stuff sold so far
Anything any of you need, just ask, In regards to price, my price range is just the price that this stuff normally goes for,
PLEASE CONTACT ME VIA PHONE - 0422 082 770 (IAN). DO NOT REPLY VIA PM
https://www.sau.com.au/forums/topic/58805-wrecking-si-r33-gtst/
- dash surround plastic with all attachments ( bottons, clips, clock, vents ,coin holders etc etc )
- gear stick plastic surround including ash tray
- drivers side plastic arm rest with window/ door control switches
can you send me pic's and prices to : [email protected]
cheers
ron
pm me on price of these please
1: the dash surround around clock hazard switch that goes down around the stereo. without swithes.
2: both sunvisors
3: standard steering wheel
also pmd you
hey mate, interested in, 5spd gearbox, flywheel, tailshaft, clutch, pedal box, slave cylinder, mater cylinder and pressure plate, how much and wat condition?? thanks
Hey
do you have this plastic panel section that clips on under the steering wheel under the dash? it has about 5 clips that hold it on, they snap easily, is this part available with all clips intact? See image attached.
Also the drivers side a-pillar, is this available, without any holes drilled in it or clips missing?
cheers,
Chris.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
