  • Replies 300
Posted Images
yeh i got 20cm 2.5" stainless steel intake pipe. afm on cooler pipe. its on the turbo pipe, which isnt recommended (as its hot air, and afm reads inaccurately), but i dun see any room on the cold pipe to mount the afm. didn really eliminate backfiring, til i got stand alone engine management.
bov blocked off..got a whole new stainless steel pipe made for it
doses n spools like vl turbo..alright to show off, but the high pitch dose really gets to u after a while..unless u got loud music inside the car :)
this thread is a joke, to all the morons obsessed with the fluttering noise, the only real flutter that sounds any good and is the cause of something useful comes from a wastegate, preferably an external one off a big turbo. Otherwise dont bother trying to obtain the noise through other means because it never sounds the same and it never sounds cool, its merely an imitation of wastegate flutter. People talking about thick intercoolers and huge pods giving the best noises rofl...its hilarious. Why would you want a 110mm thick intercooler on a car running a stock turbo that cant possibly flow enough? Oh to get the flutter lol. Sad that this thread only comes from last year, you'd hope its from like 2003 or something when imports were new and people wanted to make them "fulleh sik" with flutter noises.
Edited by 33NIZ
LMFAO...
erm you are taking the piss aren't you? RE: Real flutter from Wastegates
LMFAO...
erm how so? What exactly do you think a wastegate sounds like when you back off, im not talking about when its open on full boost obviously.
from one of HPI movies HKS street drag meeting... all the gtrs had fluttering when backing off its real fast and sounds way better than a bov flutter...but i dont think this was from bovs .. could be other factors...but very lound and fast flutters
but i was also under the impression that any aftermarket bov will flutter at low rpms (or before you hit boost) ? not quite sure... please do advise me
Edited by DaGr81
Dude, please... do us a favour
www.howstuffworks.com
Go and read, understand, and re-read just for out benefit so you can understand the basic function of car parts
And then read this entire thread as its probably been covered a dozen times.
An external wastegate does not give you flutter. ;):no::no:
Regardless of... backing off, on boost, cruising with your homies, having seks with your mrs in the back seat.
External gates have absolutely nothing to do with "flutter".
Dont try and agrue the fact that it does, otherwise ill even link a video of my car and you can hear for yourself that there is no flutter due to a wastegate.
Simple.
Well its been around 4 months since the last time I blocked off my BOV for some fully sick flutter. The last time I did this my car kept stalling and I could always smell fuel so I changed it back. I decided to try it again a few days ago and so far my car has been running really well. I used the old coke can trick and blocked off the Manifold pipe. My car hasnt backfired since and seems to be starting up alot easier. The gear changes also feel alot quicker. If my stock BOV is getting old can it casue the car to backfire and not start properly? Flutter is fully sick, lol :glare:
QUOTE(R33HVN @ 19 Jan 2007, 01:46 PM)
But flutter on standard skyline ceramic turbo = no go zone unless your looking for an excuse for a bigger turbo.
My 2 c.
Then why didn't mine come with one from factory? (hr31 coupe)
You should give Nissan a call and ask em...
this is a quote from http://en.wikipedia.org/wiki/Wastegate
Wastegate chatter myth
The noise is in fact the air compressed by the turbo passing back through the compressor housing of the turbo after having hit the now closed throttle plate.
A blow-off valve (BOV) will usually eliminate this noise, but in some cases, i.e. where it doesn't open fast enough or is setup to only react to high boost, some chatter will remain.
Turbo Flutter = Fully Hectic ... remove the BOV and seal the hole up my friends.. it does no damage to anything and that's a promise.. the only reason nissan even use BOV is due to old men not liking the sound when they drive the car.. they didn't put it on there to protect anything but our ears.
ceramic exhaust or compressor wheel?
bovs i believe came factory on turbo nissans late 80s
so like 89 i think the mainstream run for the bovs
as nissan (probably) found they increased turbo reliability and emissions
the bov was fitted on factory cars for a reason
take it off or block it if you wish, but its doing some damage
how much i cant say, but its doing some
the service life was changed after bovs were factory fitted
so there is obviously some justification behind it
Just out of curiousity how is it possible for air to flow back through the comp wheel? like im guessing it doesn't stop the impeller spinning, but how does it happen, does it flow back through the comp housing and whilst stopping all air slow down the impellor heaps or does it just travel around the impellor or wa? Was trying to figure it out the other day
I wish someone said that to me and backed it up with a "i'll highflow your turbo if it blows".
I just wonder how many people its happened to? I changed from a bleed valve to a EBC, put the boost back to where it was and blocked the bov to see how it would sound, then BANG. Both compressor wheel and exh wheel shattered, both wheels were ceramic aswell scared the shit out of me to be honest.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
