  • Replies 300
Posted Images
haha, shows how busy I am at work :rofl:
Your turbo will be fine, there will be no damage to the shaft or bearings. The amount of pressure going back through the turbo is nothing. There is no proof that it wont die becasue there is no proof that it does damage, lol :laugh:
The sound is already starting to piss me off (As well as having to fight off teh chicks) so I'm taking out the home made gasket and am going back to the stock plumb back.
It was fun while it lasted but I cannot afford to screw my turbo or have too many chicks chasing me cause i got a gf and I'm saving up to do a bit upgrade and i don't want to screw around fixing shit.
i have a turbonetics raptor bov on my s1 gtst and it makes the flutter noise sounds great
and as of yet have not had any problems with the turbo or engine. bov not plumbed back tho - just vents to atmosphere.
i think this bov uses a different type of plunger to most conventional bov's, and gives it a cool unique sound
My blow off valve was blocked when i bought the car and hadn't worried about doing anything about it; until this morning. I decided to unblock it to see the difference... and i'm glad i did. The car drives so much smoother now! I had no idea that it would make such a large difference. In my opinion the issue isn't whether or not it will damage your turbo... but the loss of drivability. Plus the flutter gets annoying after a while... its loud even when driving off-boost below 3000rpm.
by doing that u are forcing all the air back through the turbo as it has nowhere to go this is called compressor surge and that is why the stock vehicle has a BOV it is bad the fluttering is the sound of air being chopped by a turbo that is slowing down. at least thats what i read my 32 has the flutter sound i installed a huge turbosmart supersonic bov when on low boost it flutters on high boost its like an air compressor exploding its great. got sounds for all occasions lol
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
