  • Replies 635
or it could be a cryo cooling kit that drops the intake temps down a few degrees in anticipation of a drag race.
Given all the crap about "nawwwwwws" in the movie/s, I am guessing its meant to be NOS. It was probably just a smoke machine, however.
LW.
Did anyone bother to notice the car the to crooks that broke out of Parramatta Gaol the other week were caught in in good old down town MINNOOOOOOW?
Yeah a freshly imported white r33 that they just happened to end up crashing.
yippee more Skylines in the news :bs!:
just goes to show that even so called experianced drivers crash skylines aswell
hahaha can of coke... but ive never even heard of nos been vented before, why would it need to be vented etc etc??
its like a blow off for nos...
obviously it has to go some where otherwise will just sit in the pipes, so it releases the pressure by venting into the atmos, usually need it when running alot of nos
Yeah! I saw/watched it taken into the holding area under Campbelltown Police Station, it really nice from the passenger side, but the driver's side looked very ordinary.
Hey some guys that go to jail and get out want women (hehe or a guy) some want a skyline i know which one id pick 00skyline00
You sure?????????
You bought a Skyline for what? Don't tell me the legopener characteristic never crossed your mind.
Your 18 and think cars are better than women, you better re think that, I know what I would pick, but I'm a bit older than you and have experienced them for longer.
I took my R34 to Highway Nissan in Brisbane the other day. To get them to check the Fault 21 code on the ECU. Left the car there at 10am. by 4pm they called me and told me that they haven't done much to my car, coz their computer won't plug in into mine!!!
6hrs to tell me that? Makes me wonder if they couldn't find where the consult port is on the car or what?!
u do get alot of girls who use guys etc, ive been through alot of shit with a few girls recently, but only one of them knew i had a skyline, because its been sitting in a workshop doing nothing for 3 months
but alot of guys do the same so i guess it works out :D
its always a :kick: when u think u actually found some one nice and they dog yah tho :(
haha, i had parked at a friends place and was standing next to the car. a little kid on a bike rides past with his mum also riding - he looked about 10-12yo. he said something to his mum, and then goes "and nice skyline".... good to see todays youngin's gettign an early start..... (probably due to the media and all...)
had a bloke come into work the other day raving how good holdens where and was getting a bright yellow sticker put on the back of his pov dunnydoor executive the old " only milk and juice come in 2 litres " . He was looking all smug so I replied " but you know only cheap wine comes in 5 litres" . He shut up then and left as fast as he could. I see him at the gym and he all ways goes when I come in.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
