  • Replies 142
Hi there,
My view is that it is a matter of saving money using the ecu that comes with the car...
Buying a PFC means I would also have to buy AFM's which will escalate the costs. However I have been seeking information and experience using the Djetro unit eg, tuning cost differences, driveability differences using MAP, Datalogit software support for Djetro...
unless you want more than 540rwhp it will cost you $300 for two rb20/25 afms and if you are looking at more hp you should not be trying to cut cost as it will bite you in the arse later
afms in my opinion for a street gtr is a most (Drag car / track maybe not)
if you go MAP the fuel bill will kill you and will easily pay for the afms many times over
only my opinion:cheers:
No offence, but that's a pretty narrow way to compare MAP against MAF dude
If he's looking at more than 540hp, even anywhere lower, there are so many more pro's and con's for both than just fuel conservation ...
Last time Aidwin Micko and i went on to new norcia the only GTR of the three at the time that was fitted with a MAP sensor had by far the best economy just make sure its tuned right and closed loop is set right.Aidwin has a MAP setup now and its good on fuel.
MAF is a lot easyer to tune on a 6 Throttle body GTR tho.
I dont post much on these forums anymore, but i've used a few workshops to get the work done on my car. Most recently i have used hyperdrive and found their service, advice and workshop to be the best. Their workshop is clean and organised, their knowledge excellent and their manner friendly. Some workshops i have walked into i have almost broken my neck tripping over the engine half pulled apart, the gearbox lieing in the way or the bit of oil spilt that hasnt been mopped up yet.
I had my car built and tuned at SST, I got my bits and pieces from Wheelspin and Steve Lee would service my car next door at Performanz. Now with Steve Lee, Les and Paul working together at Wheelspin in Welshpool, and SST living on at CMP its even more convenient.
Also, I used to take my car to XSpeed and I found them very good too.
I just booked the skyline that Im interested in buying in for a check over at Hyperdrive next friday, Its only $180 and from what Ken said on the phone it seems that they do alot more than an RAC check and that would have cost me over $250.
Well I thought I would follow up on my tuning experience at Speedworks.. My R32 GTR was tuned by AJ. With me being from Karratha, the car was tuned and then backed off a little to allow for some safety factor and headroom as Karratha is not really the perfect environment for performance engines..
I have a printout for 416.9awhp, and the car put down 2 consecutive 420hp runs, the car was hten backed off as mentioned above. Not having driven the car yet at all, I can not comment on the tune, but will be able to feedback on this once the car gets delivered to me...
nice yorik, speedworks dyno is a hub dyno yes? just a word to the wise that a hub dyno figure isnt compariable to a wheel dyno unfortunately but they are are a great tuning tool as a yard stitch (before and after etc) hope all goes well for you and your ride
pete
pete
I think you'll find it is compareable to roller dynos, usually on cars that are making reasonable power 2-300ish the figures are usually 10ish or so hp different from the hub to a dyno dynamics unit..
where you will see big differences is big hp cars which see wheel spin on roller dynos, when you eliminate the wheel spin factor you can see very big power differences, also incorrectly tied down cars, under inflated tyres etc can also make a roller dyno figure change...
as can having a couple of fat blokes sitting in the boot to stop it wheel spinning..
Hub vs roller dyno's.
From what I've seen it depends. I've seen some reasonable horsepower differences in the two. Information from the US and the UK seems to be the same. Loses due to friction are a plain and obvious difference. There is no getting around the fact that increasing horsepower increases this loss, even when tied down well.
Like someone else said it doesn't matter anyway it's just a tuning tool. I think the hub dyno's are great being sort of portable.
Comparable or not, the car still exceeded my expectations, especially considering the tune was done for Premium Unleaded only as I can't get any better fuel up here..
In terms of comparisons between Rollers and Hub dyno's the figures are going to be close, close enough that the sorts of differences you are looking at you wouldn't notice on the street. Say 10hp on a 400hp car..
Either way, AJ was quite good, listened to my plans for the car, my situation in terms of weather and use of the car (limited use, basically a once or twice a week toy) and tuned the car accordingly, he was also very free with advice and knowledge to my questions. I have no other experiences in Perth to compare this with, but I am assuming that most reputable places would be the same.
My last car was tuned by Lumpy when he was at C-Red, and I was quite impressed with that tune, although I wasn't present for the tune, nor did I get to speak to him prior to the tune. My car survived some sever thrashing in the less then favourable Pilbara conditions and ran prefectly post install of my Tomei PONCAM's still holding good AFR's and everything running smoothly. BTW, that was a 180SX started off with 272rwhp and est 300 after cams (difference measured with GTech Pro Comp downloadable on road dyno. :cheers: )
Listen here Parkerbitch, I only know of a couple of cars that have back to backed our dyno against the hub machine and the results were drastically different. Given the 'shoot-out' method of measurement that we follow, the losses present were not related to wheelspin or inconsistent tie-on procedure in the comparison cases. 2-300hp isnt reasonable power, unless you have a WRX.
People often compare the consistency of results with the Shoot-out accredited machines, because it is a valid comparision, and a proven one at that, but the debate of a chassis dyno versus a hub mount box of oil is a little bit semantic. Remember power to the hubs isnt power at the treads! I do not know if the hub dyno operators share a code of practice and uniform method of operation to guarantee consistancy with other machines of the same make, but trying to compare one to the other is the same as comparing either of them to engine dyno's.
The chassis dyno is one of the most relevent measures of power delivery to the ground as it takes into account all factors effecting what makes the car move.
Ignoring politics etc, either device is a capable tuning weapon, each with benefits for and against and not really what this thread was for.
hyperdrive is the go in perth :P
lumpy u r getting grumpy in your old age haha, u gotta treat customers with respect, haha jk, u done a great job on all my cars and he even has done work on them at my own house saving me getting the car to the shop :(
thats only for me i presume so dont go asking for a home service or something from glen and ken :D
just a note, shops and certain unnamed people deserve to be in jail, bloody greedy theiving arseholes around, and also PSI Performance, dont get me started please... i got the good work of brett a few years ago and he pulled my CAS apart with a bloody hammer and chisel in the vice like a butcher, and the autronics ecu wiring was totally arse around and coils were wired in wrong order, so i wouldnt trust him with a bloody datsun 180b.
pm me if people want info on dodgy dickheads in perth :)
arh well enough whinging
cheers :)
Brad
  • 1 month later...
who can or who will?
as for who can any tuner pretty much can as their simplicity allows even the most futile of tuners to program them
just expect it to take some time to get certain aspects correct such as coldstart etc
as for who will... well the list narrows rapidly...
due to the interesting political nature of the car scene several ppl wont touch it with a 10 foot pole
some tuners hate the ecu itself and refuse to waste thier time on it
your pretty narrow in your choices, and with rumours that one of the few ppl that will do it will be without workshop soon may mean wolf is totally out of support in wa very soon
as for price
different shops charge differing prices
if you know someone you can pay as low as 50 bucks an hour
i believe speedworks now charge 200 an hour?
i know hyperdrive and xspeed will be less then that
do the ring around
pray beg etc
see how you go
p.s i pray no one takes anything that ive said personally im just trying to relate this in a real world sense for someone who needs help
nothing is meant to stir or cause shit. if someone chooses to view it that way then sorry but sucks to be you.
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
