the stock maps are fairly rich for protection reasons but it should still enter closed loop on low throttle. as long as 02 feedback is turned on of course. 250km's to a full tank is resonable in an un-tuned state
Quick Question...
- AVC-R
Or
- Boost Controller Kit
for Power FC?
Is it personally preference of would the boost controller kit for the PFC be better cause its also controlling the rest of the engine as well as being cheaper than the AVCR (AVCR = $580) - (PFC Boost Controller = $400)
Give me your thoughts...
so no disadvantage/advantage over the two... apart from having an AVCR on my dash and someone decides the would prefer it off my dash and in their corolla :D
It has a bit of a wank factor... Also with the PFC do you have to leave the commander connected all the time, can you like take it on and off at will if its in the way or soemthing?
After reading the faq, I still needed some more convincing on the PFC with an auto, so i've made a new thread so as not to bring the conversation into here:-
http://www.skylinesaustralia.com/forums/in...showtopic=97698
So yeah, i want to know once and for all if the PFC will work with the auto.
Cheers.
hey ive have plugged in my power fc and its hasent been tuned yet.
the engine light stays on and the car constantly stalls. it also feels like its skips and hops going up through the rev range. all was fine with my stock compter.
i need to keep the powerfc in fow a couple of weeks till i get it tuned, is there anything i can do to fix it? like reset it or sumthing?
make sure the boost controller kit is turned off (says that in the faq) and if that doesnt make the engine light go off, try a full reset via ETC then turn the key to ACC, turn off boost control kit and then start car and let it idle for 20 minutes. follow the procedure correctly for first time "init" of the powerfc as it has to learn the idle
I dont know if this has been covered but I just found you that you can get number rating for the knocking levels with your car.
Just press the UP arrow, and it will show digits for knocking. So basically it will show you the peak, in a digit and not just upon the bar graph
updated:
added boost control kit hookup
added boost control kit configuration
added boost display without using boost control kit
added apexi other piggyback systems
corrected grammar with powerfc pro
expanded more on apexi boost control kit functionality
Paul
I bought a AVCR boost pressure sensor from Nengun. I have a 3 pin plug for my power FC. It reads boost but its wrong. I have my set my boost pressure at .65 bar via the power fc to read 20psi at my guage. My low boost is set at .50 bar.
I believe something is wrong with the boost pressure sensor? I had to manually wire it up as it didnt have the correct plugs. Any ideas as i have double checked the wiring.
sorry robo im a bit confused. i dont know for a fact the avcr map sensor is the same, it should be. can u give me the denso part number from it. the map sensor should attach to the 3 pin harness. the boost solenoid should attach to your stock wiriing. when you goto setting, boost what option is highlited and whats it set to ?
heres one for ya, my battery went dead flat and car sat there for 2 weeks, i jump started the car from a charger/starter pack and now engine light is always on and car stutters while cruising every couple of seconds. We went to a local tunig shop and they had a customers car with brand new power fc and we used that commander as i dont have one for mine. It plugged in and just came up with the apexi logo and thats all it would do. Are the commanders only suited to that specific ecu of should it have worked? Also any ideas on wether something has been reset or blown due to the flat battery then jump start? driving hard it seems to run fine with no stuttering but its when you sit on a constant cruising speed and also does it worse under less load. also after working on it tonight the voltage off the battery is at 14.8-15.5 volts whilst running and the battery light is now on!!
Bet ya this stumps ya!! lol
Edited by DRIFTPIG
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
