the stock maps are fairly rich for protection reasons but it should still enter closed loop on low throttle. as long as 02 feedback is turned on of course. 250km's to a full tank is resonable in an un-tuned state
Quick Question...
- AVC-R
Or
- Boost Controller Kit
for Power FC?
Is it personally preference of would the boost controller kit for the PFC be better cause its also controlling the rest of the engine as well as being cheaper than the AVCR (AVCR = $580) - (PFC Boost Controller = $400)
Give me your thoughts...
so no disadvantage/advantage over the two... apart from having an AVCR on my dash and someone decides the would prefer it off my dash and in their corolla :D
It has a bit of a wank factor... Also with the PFC do you have to leave the commander connected all the time, can you like take it on and off at will if its in the way or soemthing?
After reading the faq, I still needed some more convincing on the PFC with an auto, so i've made a new thread so as not to bring the conversation into here:-
http://www.skylinesaustralia.com/forums/in...showtopic=97698
So yeah, i want to know once and for all if the PFC will work with the auto.
Cheers.
hey ive have plugged in my power fc and its hasent been tuned yet.
the engine light stays on and the car constantly stalls. it also feels like its skips and hops going up through the rev range. all was fine with my stock compter.
i need to keep the powerfc in fow a couple of weeks till i get it tuned, is there anything i can do to fix it? like reset it or sumthing?
make sure the boost controller kit is turned off (says that in the faq) and if that doesnt make the engine light go off, try a full reset via ETC then turn the key to ACC, turn off boost control kit and then start car and let it idle for 20 minutes. follow the procedure correctly for first time "init" of the powerfc as it has to learn the idle
I dont know if this has been covered but I just found you that you can get number rating for the knocking levels with your car.
Just press the UP arrow, and it will show digits for knocking. So basically it will show you the peak, in a digit and not just upon the bar graph
updated:
added boost control kit hookup
added boost control kit configuration
added boost display without using boost control kit
added apexi other piggyback systems
corrected grammar with powerfc pro
expanded more on apexi boost control kit functionality
Paul
I bought a AVCR boost pressure sensor from Nengun. I have a 3 pin plug for my power FC. It reads boost but its wrong. I have my set my boost pressure at .65 bar via the power fc to read 20psi at my guage. My low boost is set at .50 bar.
I believe something is wrong with the boost pressure sensor? I had to manually wire it up as it didnt have the correct plugs. Any ideas as i have double checked the wiring.
sorry robo im a bit confused. i dont know for a fact the avcr map sensor is the same, it should be. can u give me the denso part number from it. the map sensor should attach to the 3 pin harness. the boost solenoid should attach to your stock wiriing. when you goto setting, boost what option is highlited and whats it set to ?
heres one for ya, my battery went dead flat and car sat there for 2 weeks, i jump started the car from a charger/starter pack and now engine light is always on and car stutters while cruising every couple of seconds. We went to a local tunig shop and they had a customers car with brand new power fc and we used that commander as i dont have one for mine. It plugged in and just came up with the apexi logo and thats all it would do. Are the commanders only suited to that specific ecu of should it have worked? Also any ideas on wether something has been reset or blown due to the flat battery then jump start? driving hard it seems to run fine with no stuttering but its when you sit on a constant cruising speed and also does it worse under less load. also after working on it tonight the voltage off the battery is at 14.8-15.5 volts whilst running and the battery light is now on!!
Bet ya this stumps ya!! lol
Edited by DRIFTPIG
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
