I've asked about it from a few tuners and all have reported to just leave it and dont change it
Ive connected a Wideband A/F guage and if i give it medium throttle, it richens up to say high 11's and then goes to mid to high 12's once your on the throttle and the accelearting enrichment has gone. This is only on medium throttle with very little boost. I played with it and now im in the 12's and ive noticed an improvement in throttle response. '
I'll do some more testing and leet you know how i go.
expanded on bad idle problems (how to correctbad idle / cranking / starting problem)
added evo8 support (harness part #)
added eccs wiring howto (bugfix to correct memory save problem)
added dialing in larger injectors
added authors notes
Has anyone tried playing with the Accelerating Enrichment program on the Power FC?
Here's some info I posted elsewhere in a Datalogit context.
The "Inj vs Accel TPS1" area of the 'settings 2' tab affects the
linearity of the Accelerate Injector settings. You don't want 100%
of 'accelerator pump' settings to kick in when you just apply, say,
a 25% change in throttle position. Nor do you necessarily want 25%
of the extra fuel. The 'input' field is throttle position in units
out of 256. (128 = 50% throttle) The 'setting' field is the fraction
of Accelerate Injector setting out of 256 that will be applied give
the partial throttle increase. There are three 'linearity'
adjustment points, but be aware that there are two more fixed ones.
(0,0 and 256,256)
I've found that I need to set the first 'Input' box to a pretty low
TP number (5/256) and give it a fair shot of fuel (175/256) to avoid
leaning out under modest throttle increases. The PFC linearly
interpolates between these points, so for throttle positions between
the linearity adjustment points, you'll get a smooth transition.
Hope this helps,
Dan
corrected powerfc dongle information
added INJ guesstimation for lambda
added airflow precentage correction map scaling
added updated datalogit version
added missing eccs image
hey i just went through and wrote every single bit of inforamtion down from my pfc, the ign and inj maps and other thibngs like the water temp screens etc etc..... took me a bit, am i right to reset the pfc and reload those valuse what do i need to be careful of (its just when they tuner put my pfc in he didnt do the idle learn thing with the a/c etc so my idle hunts)
  • 3 weeks later...
added repairing powerfc notes
expanded on airtemp support
added knocking explantion with likely causes
added advanced knock debug
added datalogit AFR plot
added rb20 vs rb25 pinouts
added r33 sensor SW check page
added R32 sensor SW Check page
expaned on hybrid version support
- differences between RB20 and RB25 looms
- support matrix for features
There's an error in the FAQ. The R33 BCK is 3 pin for the MAP sensor harness to PFC, and the solenoid harness plugs straight into the harness for the oem solenoid.
You can control boost using the oem solenoid with the BCK MAP sensor (I tried this) but the control is awful, as you'd expect from a 2 port solenoid.
Hey guys,
Great thread!
I have a question.
On the old Nissan ECU, starting the engine was no problem at all. Sounded like 2 cranks and she lit up every time.
With the Power FC after, a full tune by the Hitman and the 30 min warm up idle setting, it takes about 8-10 cranks to start.
It starts every time, don't get me wrong.
Just thought it strange the standard Nissan did it better than the Power FC
Any settings i could be looking at?
Thanks
Birnie
Chris (png_gozilla) please see here ->
http://www.skylinesaustralia.com/forums/in...howtopic=127769
I moved your post so youll get a better answer in that section
hi, I've actually bought a used FC that has been in a car and tuned to 230rwkw with stock everything except cat back 3" exhaust. I have a full engine rebuild with ARC air box. full 3" to 3.5" exhaust will it be ok to plug it straight up or too much of a risk???
Also, i have an AVCR installed but never turned on, can i just use that boost kit and harness for the FC??? Or get it tuned straight away???
Just wanna be sure before i do anything??
Cheers in advance..
Edited by ib6ub9
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
