Ohhhk I'm going to take back my last comment with regard to Haltech Platinum Pros.
This what my tuner (XSpeed) said about the Haltech Platinum Pro...
"Just don't."
I said "please explain" and he said....
It's a universal ecu that isn't tailored for any particular car with all sorts of tuning issues (cost the last guy $1700 in labour alone to get it working 80% of the time lol)
He went on to say that the measuring parameters of the Hally are far too wide to tune one specific street car effectively and would only really be superior if it was for a dedicated track car where normal reliability issues mean jack shit. He said they've tuned every ecu under the sun and the Haltech PP has returned reliability issues with cold starting, idling, hot starting and O2 sensor issues basically all the stuff you need to work 100% for a daily drive.
He seemed to think the AP Engineering Apexi PowerFC for the RB20DET was the beez neez. Easy to tune, designed to work with the rb20det specifically, excellent reliability.
James
Edited by plan-b
hey guys,
I have just been going through my pfc screens trying to find out whats going on with my o2 sensors and found out they were turned off.
I replaced the sensors and turned it back on but there is another setting (02 sensor reg).
Does this need to be turned on as well.
I have had a look through pfc manual and looks like it may be for the bncr32 and needs to be turned off, but not sure.
The car is a r33 gtr
ok, read whole 40 pages and found this
the 02 sensor as its a RB26 PFC will expect R32/R33 GTR style sensor as you have GTST it wont work correctly
youll either need to run without 02 feedback completely or change your 02 sensor to the GTR style 02 sensor
if you go for NGK BNR32 style 02 sensor you can set "02 registered" in function select to run in BNR32 mode
otherwise get a GTR33 sensor and leave 02 reg off but have 02 feedback on and it should be ok as long as you have the same GTR33 sensor
you can splice up the output from the 02 sensor and run it into both 02 sensor inputs on the RB26 loom to the PFC so both 02-1 and 02-2 have the same value
answer found
thanks for the reply , i am going through all the wiring, making sure everything as you say, i will let you know when i get success
the powerfc updates the tune in real time, and then when you key off, commits the changes to NVRAM
in the powerfc FAQ there is a section on this exact issue, search in the FAQ for "ECCS" and youll find a section on how to correctly set it up
on your car, as youve done an engine swap, the ECU isn't given enough time when you power the key off, so it doesnt get enough time to save to NVRAM, thus any change is blown away
the ECCS diagram shows you how it should be setup and how it needs to be wired in
Edited by Reecewashi
  • 1 month later...
I have a R32 gts-t that is running a Power FC, was tuned almost 2 years ago and haven't had any major problems since.
About a month ago I removed the throttle body to fix a coolant leak and ever since then I am getting a lot of idle hunting and sometimes when coming to a stop the car will stall.
This isn't consistent however, it is mostly ok when cold, but even when hot sometimes it isn't issue.
I have cleaned the AAC valve and have played with the TPS(as this is the only thing I can think of that would have been changed when I removed the TB) which currently sits at 0.4v on idle and doesn't move around.
Any suggestions for settings on the PowerFC I can play with to settle this?
Edited by Kwyjibo
there arent any other than DATA INIT to perform self idle
i can only suggest key to ON but dont start car
check TPS is 0.30ish at idle or adjust to make sure its around 0.30v and floor it and it should peak near 4v
the nissans service manual has what value it sould be at idle as i dont think it should be spot on 0.30v so best to check it
  • 1 month later...
Hi all,
A friend of mine just recently imported a modded R32 from Japan. Its got some extensive mods and looks like it could put out about 400awkw once tuned...
Unfortunately the ECU was replaced and a stock one is in the car now. Just wondering - is the PFC the best option that's not going to cost an arm and leg?
Other options explored was Motec (too expensive) Haltech (not sure), Link ECU (again dont know anything about them) Nistune, etc...
If there are any con's with the power fc, what will it be?
any feedback much appreciated!
Edited by ironpaw
go read the powerfc faq, it has everything covered already
no known issues with using a powerfc on that car
ask who ever is going to tune it what ECU they prefer
no point going to someone who only tunes vipec's with a powerfc and vice versa
hi guys,
got an issue with my pfc. its at the tuners at the moment and he cant get it to rev past about 6100rpm. he said he has all the different rev limit settings set at 8k and he also swapped the pfc out for the stock computer and then the car revved fine so obviously somethings going wrong with the pfc.
any ideas?
pete at jaustech. he said hes spoken to a few people about it and no-one has a clue why its doing it. rekon it might be a faulty pfc.
hes sent an email and is waiting to hear back from apexi about it
i assume so. he said hes saved the map so if i did have to get another pfc he could load it straight on.
thanks for the offer steve, ill wait to he back from him again about it anyway.
  • 1 month later...
did a search but cant find any thing, im thinking about getting a map sensor to hook up to display boost and peak hold on the hand controller, just wondering if it is possible to hook up a solenoid for boost control, if so any idea's what wires go to the solenoid?
normally its sold in a kit as the PFC boost kit
i have the solenoid i cant remember if i have 100% of the wiring but i don't have the map sensor, was all bought 2nd hand
i since bought a AVCR for electronic boost control
Yeah I know, but all I wanted was the map sensor to display boost, with the wiring you cab get that for $50+pp from the states, then I started wondering if I could hook up my current boost controller solenoid to it and have it work, the solenoid may not work but if know what wire to hook up to it then its worth a try
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
