Faq: Apexi Powerfc - Frequently Asked Questions
paulr33
  • 1 month later...
updated PFC FAQ
first update since july last year
- apexi are now selling ECR33 and ER34 models brand new
- you can buy these from nengun.com including EL hand controller
just wanted to say thanks for this thread/article, some great info.
i've managed to modify my standard ecu bracket to house the pfc, allows me to plug in the hand controller without issue and sits perfectly in the standard spot... anyone handy with the tools should give this a go :)
Edited by tgz
  • 5 weeks later...
Hi Paul. I'm trying to install a monster tacho into my r33. I also have an special power fc. Can you please tell me which is the rpm wire to hook up to the tacho?? Your help will be muchly appreciated.
cant you just take the cover off your factory ecu and screw it onto the power fc?
what is special about your powerfc?
you need to look up the pinouts for the R33 and then wire the signal wire for the tacho onto the guage
because you are using a powerfc it makes no difference, its the same RPM pin out if using the stock ecu as well
FYI Paul those new Power-FC's that Nenguns is selling have a 2+ month wait on them. I went through hell trying to get one through them in a resonable time and ended up cancelling my order and getting one used. They do have decent customer service though.
  • 2 months later...
Paul: Is there anything different with the new Power FC's or are they just re-released with new chips?
Also 'STATUS' was talking about there being some trouble with the tuning software communicating between laptop and ECU, any word on this?
Sorry if its covered in the FAQ, couldnt find it and just wanted to know
no idea sorry. all i know is it has a new version and also the el hand controller
i asked for some info in the thread that status posted but i dont think he replied
Yeah I think I asked some questions as well but it seems to have been forgotten
was going to PM STATUS but doesnt look like he accepts PM's
Just wait and see I guess. I might be getting one so hopefully my laptop will talk to it
My car is in the shop at the moment and the guys are unable to get the ecu to communicate withe PC. Not 100% sure on the issue but will find out more tomorrow.
They are waiting on a reply from fc datalogit but from what I have read I dont think I should hold my breath.
    • Got some decent progress after work yesterday and also today. Got the ECU all wired and passenger side interior all back together. Kept the wiring up nice and high to avoid people standing on it. Got the surge tank relays rewired and tidied up the pump wiring and cut a hole to bring the cables through.  I found a spare USB cable I had lying around so I decided to cut it up and see if I could use it for my CAN 1 bus. Turned out one of the pins I needed was to the shield of the cable so i cut it up and desoldered it and resoldered to the correct pins.  Had the issue with the powersteering hose hitting the A/C compressor and fan shroud. I pulled the bracket off and modified it to remove the front mounting point which now clears it all. Will keep an eye on it to see if theres any signs of fouling once it's up and running.
    • That's some good input mate. Nice.
    • So today I went well outside my comfort zone (again) to replace my valve cover gasket.  I have had a big leak over the exhaust leading to a lot of smoke and smell every time I drove it. The leak was in the rear driver's corner.  The job wasn't hard as such, just a bit finicky and time consuming.  The old gasket was rock hard and broken right where the leak was.  The leaky corner had so much sitting oil in it.  The good news to my amateur eyes was no buildup or sludge under the cover. It all looked fairly nice in there.   I haven't started it yet. I ran out of light and body when putting the coils and injector loom back in. Probs only 30min left for the morning.  I was so nervous putting the cover back on, I must have lifted it 5 times to make sure the gasket was still seated properly. God it's going to be nice to be leak free and not make other traffic light queuers think my car is about to explode.
    • Gave the Mazda it's first wash, it will need some clay, a light compound, and polish polish to remove a few swirl marks, but that will be a job for when I have a full day to get my DA polisher action on
    • Just did this job on my 32 with the boost doc kit. was quite simple to fit, hardest part was getting the rubber bungs back on the firewall. does anyone know how the heater will work now without the flap in the bend? Will I just have a heater on 24/7 now?
