Cheers dude. Few thats a bit of a relief though, thought that the rear bumper was different but couldnt tell from the shadows.
It is so bloody frustrating to wait for a car, don't know how you regular importers do this all the time. :( I guess it will pay off in the end though :D
DAMNIT! why does everybody else have nice plenum and mine is missing paint allover! arrrrr
mark
hahaha, you buy me nismo one and you can have my one mate :)
That's what I'm willing to do for a mate :)
Yeah it looks a bit weird. Depends on how it looks I may get it repainted. Does it look ok in your opinon or would it look better being the same color as the rest of the car?
yeh it looks beter all painted,
but i respreying the whole bar for it
looks cool mate. As a side note, does anyone know what the crossed out number plate means? I'd always thought it meant that the car had been defected (cause I'd seen it on some heavily modified cars in Japan).
Also, make sure you get underneath it straight away as the pics of the car sitting in snow aren't a good sign rust wise...
hey guys, lots of nice looking GTRs, makes me even keener to get mine.
OohArrGTR, ive seen you around newi, looks fat. u dont need to use heatproof paint on plenums and what not, i used it on my exhaust manifold and thats it, for everything else i use regular acrylic paint in a pressure pack can. cam covers, other bits, brake calipers, brake discs. but why not polish it up?? ive done my inlet manifold, looks sweet.
well, you could take it all off and get it polished up, or you could take it off and buy the equipment and do it yourself, or you could take it off and rub it back with wet and dry, goin down in grit, or you could do what i did and leave it on the car and sand it back and getting lookin really smick in the areas ppl see. it takes a while, but i think on an rb26 getting the paint off would be the real trick, then you have to get the casting marks out of it. took me a few days, im still not quite finished.
cheers
Linton
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
