yeah I fired it up a bit yesterday, Got stuck with some class one dickheads in the Mx5s; they were going hella slow around lime rock and because I didn't qualify I started from the back, trying to work my way through and they just would block me on the straight and just be assholes. I managed to get around most of them by driving in their blind spot for a few corners and then sneak past exiting the corner. Still managed to come 2nd :D
Had a go at oval too, figgured I suck at that, I was OK in the legends and manged to lead for a few laps but I'd just cook my tyres and run wide into the walls :(
The biggest and most enjoyable thing I found was getting out of the Rookie/Class D series, with maybe the exception of the Skip Barber, as that's a fun car to drive as long as the racing is clean. I'm happy they've made the Radical a class C car again with races going off every couple of hours, because the Radical is an awesome car to drive. It's one of the ones I can actually drive on the limit strangely, I can't do the same with most of the open wheelers... I seem better with tin tops like the Mustang etc. *shrug*
And yeah, jerks in the MX5 blocking is annoying.
  • 4 weeks later...
2 of my hoes' , one is the dirty broad minded person you thrash the f**k out of , the other is the good girl you take to meet mum and dad :) , both need a wash atm , but i just brought the 34 down to my work to pull the locks out to send away to get fixed :) , it hadn't seen the road in over a month? , and a blown 3rd gear 20 box (the first and only one i've blown so far) and the new dash i made for the hq and my new tow bus :)
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
