Hey guys,
I need my timing belt changed. I've bought one and i have it's gettin put in on friday for a bit more than i'd like. So if anyone is willing enough to spend some of their time and know what they're doin, i'll give ya 2 free slabs or cash equivalent :D
https://www.sau.com.au/forums/topic/68704-2-free-slabs-anyone/
Doing a timing belt on a 33 is no easy task, especially without the right tools. Ring around and get it done at a w/shop.
My Mechanic:
EAS performance
Contact : Vic
Tel: 9330 2001
Add: 11 Victory Str/Rd, Airport West (near Tullamarine)
I have been going to Vic for the last 3 years without any drama. A few of my mates also use him and have found his work to be of a high standard.
timing belt is an easy job....the only special tool needed is a balancer puller and its about $20...and there ARE certain shops i wouldnt be taking it to....for fear of been lied to and torn a new arse in the bill department...what area are you in?
I'm in the southeastern suburbs....i think i'll take it to this workshop i know of. He seems to know a fair bit about imports....anyway just for the timing belt he has quoted me a minimum of $280 to change, me providing the timing belt. He said it could go up to around 310 if something was rusted and hard to get off or something, meh i dont know, but he seemed to know what he was talkin bout
Cheers dudes,
SImon
Good luck if you can get the bolt undone. I used a 2 metre poll a hammer and some rachet straps to hold the balancer whilst it was in gear and the brakes were on and it was done up bloody tight. Read the manual to see what its done up to 270ft pounds or something like that.
You lot are limp. Ever see a real mechanic at work? We use a half inch breaker bar, an extension pipe and wedge it against the chassis rail, then use the starter motor :D I do have a tool I made to make it easier if that don't work though.
I have had bolts at 1000 foot pounds on my old Mack truck that took some sweat out of me. 270 is like lifting a slab of beer. It's all in the way you hold your tongue :D
Sorry but I'm not doing any work for anyone at the moment. Too busy getting ready to sell the house so I can "punch out" of Victoria for good. (caught up with some jet jockey mates during the airshow so adopting new cool additions to my vocab, still concerned at a helo pilot using that one though...talk about mental images of slice and dice)
While it is apart I recommend the idler and tensioner pulleys be changed. Do a search for the thread that details it all.
Why not give the boys at chasers a call>? They just moved shop to near footscray (end of dynon road next to toyota dealership) so its probably a bit out of the way, but they do good work and its all guaranteed.
Call Benny - 0433 184 724. He's a bit of a smart arse but he does good work.
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
    • I spotted a black C34 in Mittagong this morning!
