Does an rb30 bottom end with rb30 crank bolt straight onto an rb25 head?
Im thinkink of strengthening my bootom end as i am about to put a larger turbo in my car.
Does anyone have some feedback on doing this and also is a ihi apexi rx6 turbo a good upgrade for a gts. I can get a brand new one pretty cheap!!
https://www.sau.com.au/forums/topic/7267-rb30-bottom-end/
confak,
I'm pretty sure that it does bolt straight on, but that the oil and water galleries need to be moved. I'm sure someone out there knows for sure. The RB30 won't strenthen the bottom end just by putting it on, you'll have to look at doing things to the crank, pistons and conrods to make it tough. The extra 1/2 litre will make a larger turbo more responsive though.
Remember the RB30 was only put into shit cars, VL Turbo etc, so I can't believe that the bottom end will be too stronger, but I haven't tried it.
See'ya
:burnout:
https://www.sau.com.au/forums/topic/7267-rb30-bottom-end/#findComment-107052
[cough] say what ?!? - the RB30 is used in Oz spec R31 Skylines and Nissan MQ Patrol's. Holden bought the RB30 to put in the VL when they realised the 202 (read: boat anchor) couldn't cut it with unleaded fuel. The bottom end of the RB30 is as strong as any of the RB series.
As for the RB25 head, the non-VCT head bolts straight to the RB30 block without mods, but the VCT head requires oil gallery mods.
https://www.sau.com.au/forums/topic/7267-rb30-bottom-end/#findComment-107174
only put into shit cars eh. do i detect someone thats been chopped by VL turbos?
R31 = shit car apparently.
SteveL is correct about the non VCT head. This head is found on R32 RB25DE engines (possibly other engines but I dont know)
RB30 bottom end strength: from what i've read the standard bottom end is used regularly in larger hp applications.
https://www.sau.com.au/forums/topic/7267-rb30-bottom-end/#findComment-107207
As well as bolting the head on, you need to modify the cambelt idler / tensioner, and you need to modify the ignition system (RB25 runs coil packs). And you need a R33 ECU to run the coil packs.
email the boys at Zoom! ([email protected]) and ask them which issue covered this conversion.
https://www.sau.com.au/forums/topic/7267-rb30-bottom-end/#findComment-107328
Now we've started a stupid argument...
Anybody done 400,000km in their RB25 yet ? Hmmmm...when u do let me know, but there are still plenty of R31's driving around that have done that many km using an RB30 engine.
There is a guy on the www.r31skylineclub.com who has a 323kw/rw RB30 turbo (its actually being sold now for 13k - see http://nissanking.cjb.net/).
You might want to check out the r31forums there for some advice, as there are plenty of people who've put Turbo top ends on their RB30's
https://www.sau.com.au/forums/topic/7267-rb30-bottom-end/#findComment-108715
ok from the research Ihave done.
unless your going for mega power forget the rb 25/30 unless you can do all the work your self.
the rb26 crank and rods fit in the rb25 and get some forged pistons if you want to run serious boost or just use forgies on the stock bottom end.
con b4 you do any thing fit the rx6 turbo but make sure its suitable for the rb25 and yes they are very good turbos.
get a power fc z32 afm and bigger injectors merli is making 280 rwkw on a stock bottom end rb25 so you can and when it blows then fix it strong but it could last for ages. If tuned welkl and looked after
meggala
https://www.sau.com.au/forums/topic/7267-rb30-bottom-end/#findComment-108745
  • 1 month later...
ricknismo,
http://www.r31skylineclub.com/content/articles
Has a artical on a twincam conversion!
http://home.iprimus.com.au/cobra30/twincam.htm
Is another site detailing the conversion! Costs is also included in this one and it goes into much better explanation on using the non VCT head!
MEGA
https://www.sau.com.au/forums/topic/7267-rb30-bottom-end/#findComment-147590
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
