Any of the high end Yokohamas. Myself and two other mates use nothing but. They run ES100s, and I run the C.Drives.
I also previously ran the A539s... All are very good in the dry, and also pretty damn good in the wet.
i got a set of 245/40/r18 Falken ZE326 and must say they are pretty f**ken useless in the wet i feel like im seriously skating on ice when i drive in the wet (complete granny driving aswell) how ever in dry they do the job well enough :)
-Ruffels
I have toyo T1S (255/40/17) on the rear (replaced by the T1R) and Maxxis MA-Z1 on the front (235/45/17). The Maxxis are sensational, especially conisdering the price. Great in the wet and pretty good in the dry. The Toyo has almost an identical tread pattern and seems to exhibit similar charateristics. Probably dopnt grip as well in the dry as i would like. But thats no to much of a worry.
The thing about the Maxxis is that they dont come in a 255 width at the moment. No idea on wear rates yet. But the maxxis on the front have done 2 motor challenge days and are holding up well.
Hey Missinglink,m
Where did you get your Maxxis from?
So far I've only found Bob Jane stocks them and the guy I spoke to (Grant from Reynella, SA) said they only had MA-V1 and quoted me prices for these. He said the MA-Z1 were available but in limited sizes in Australia and he wasn't able to quote me any prices on these.
There was a set of [new] Kelly Chargers on my GTSt when I got it, just been complied.
Tread looked OK, compound felt OK. I only put up with them for less than 1000k.  If you ever come across a tyre dealer giving them away for free - Don't take them,unless you have a death wish  { I sold them to a bloke with a Commodore.}
i agree they are the worst tyre i have ever driven on
if any people here think a ziex 326 is bad, i challenge you to try driving with kelly chargers, they redefine 'no grip'
326's are like semi slicks when compared to chargers, they ARE that bad.
wet and dry rating -100/10
My favourites on both Skylines and RX7s are Falken FK451s and Kumho Ecstas. Both are excellent in wet and dry. I've also got a set of F1s on a Skyline as well - and although I'm happy with the performance I think they're overpriced compared with the Falkens and Kumhos. They certainly don't perform better.
Sizes 235/45r17 front 255/40r17 rear. Power not too sure but last time the Skyline GTSt was on the RR it was 250hp at the wheels. Add to that 75hp nitrous and 10% toluene in the fuel should make that higher and I've had no issues.
:wassup: My goodness they must be bloody awful to be worse than ziex 326. Where are they made?
I know that some of you have tried fedrals i have some on the rear of my 33 GTST there 18/265/35 and i think that they are not bad i have 216rwkw so it not really stock but even with out the camber kit they hook up really well dry that is i havent had them in the wet yet, and i run way to much neg camber so after the camber kit they should be reall good
Hi guys
Can anyone tell me more about the Hankook K104 ($165) ????
Also about the difference in performance between Toyo TPG ($180) and Proxes T1R ($295).
I'm due for a tyre change and the above are looking like good value for money options. size required 235/45/r17
Thanks
Sumitomo HTRZ II
Dry: 2/10
Wet: 9/10
Value for money: 3/10
These tyres in the dry are shocking for traction. but in the wet the are the other way around.
The actually spin easier in the dry then what they do in the wet ???
Not the best tyre for handling, But would be good for drift. Is also a good tyre for high speed. from my experience.
Although the cost is fairly expensive, around $400 - 450 per tyre if I remember correctly.
Dunlop Sport 2000
Dry: 4
Wet: 4
Value: 4
OEM tyres for my last car. Typical OEM tyre: quiet and reasonable in wet and dry, cold and warm. Not much of a sports tyre, though.
Silverstone Something, who cares
Dry: 4
Wet: 3
Value: 3
Silverstone make some of the crappiest tyres on the planet. Every person I know who's used them has hated them; no grip and wear quickly
Pirelli P5000 Drago
Dry: 5
Wet: 6
Value: 6
These are a good wet weather tyre. Two big centre channels and directional tread. I found myself doing Old Pac in the wet only 5-10km/hr slower than in the dry. Even though I had them for longer than the Silverstones, when I had to swap 2 out due to puncture the Pirellis still lasted longer than the Silverstones I replaced them with.
Falken Azenis RT215
Dry: 7
Wet: 4
Value: 5
Everyone knows about these tyres. Didn't last long, but I could hammer my car and the thing would just stick. In the wet you noticed the lack of tread blocks, but in the dry I was finding myself taking corners flat that I'd normally have to lift on. Shame about the tyre life.
Bridgestone Potenza RE040
Dry: 5
Wet: 5
Value: 5
OEM tyres on my current ride. Great OEM sports tyre. Progressive, and with a reasonable amount of grip even when cold. They also do OK in the wet. The only problem is they can't handle heat. The first time I took them to the track, I baked them and they didn't grip properly cold after that. I'd get a fair amount of slip until I got heat into them.
Falken Azenis RS-V04
Dry: 8
Wet: 2
Value: 4
Ignore what some people tell you, Formula R semi slicks are not daily drivable. They were noisy as hell, and only by babying them did I get 8000kms out of them. I'd average one oversteer moment per drive in the wet, and they'd pick up stones and either embed them into the rubber or flick them up onto cars behind you.
But, in the dry and in anger, a Formula R tyre redefines what you think your car can do around a bend. I had a couple of situations where I went into a corner too hot and I thought I'd slide out; on these tyres the car just did what it was told. And, on the track, they'll do it lap after lap.
Definite "second set of rims" rubber. There are better Formula R tyres out there, but not for the pittance I paid for them.
Dunlop Direzza DZ101s
Dry: 6
Wet: 8
Value: 7
Current tyres. In the dry they provide good grip (at least as good as the RE040s, if not better) and in the wet they're phenominal. I can't believe how much grip I can get, even in standing water, and even when they let go its progressive and its easy to bring them back on line.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
