4 hours ago, Hadouken said:
Nt01 vs AR1. I would say they are on par.
Was looking for some new fronts for our track car today, and was surprised that in our size (245/40R18) the AR-1's were more expensive than both NT01's & R888R's - by a fair margin. I ordered a pair of the R888R's.
They start making noises and become greasy. But that's when they are so hit pressures are off the gauge. Lol.
Ummm sorry to hear that whoever you got quoted off is trying to rip you. But I paid $240 for 245/45/17 nt01s and I paid $150 for 235/40/17 AR1s
How much where you quote? I paid 205 each fitted for 265/35/18
Cheapest I could find for 245/40R18 AR-1's was $310 each, plus fitting. Other sizes are cheaper, but we want to run the widest tyre we can on our 8" front rims, so that means 245. Bought the same size in R888R for $250 each, and could have had NT01s for a similar price.
Nankang pricing was taken from Sleekaspares in Adelaide (and on Ebay).
Where was this from?
Associated tyre service, Cheltenham, Victoria. I found them and got that price through the tyrecompare.com website. When i called randomly they said 225 but then i pointed out the website price which they honoured.
Thanks - had a look at the tyrecompare website but no pricing listed for the AR-1's in SA.
4 hours ago, ActionDan said:
I got mine here.
Thanks Dan - contacted them today and they want $310 for 245/40R18's.
I know this is a new(ish) size for Au, I was looking earlier this year and could only get 235 in 18's.
There are several different width 18's on ebay that are considerably cheaper - 265/35 for $240 & 225/40 for $224, but 265 won't fit my front rims & 225 is too skinny.
3 hours ago, ActionDan said:
245 is an awkward and expensive size
Only in Nankangs it would seem - have never had issues with Nittos, and now Toyos are readily available & well priced. Not sure about awkward either - 8" is a very common rim width, and 245 is the widest that can (should) go on an 8" rim.
Only minor PB improvement which was disappointing as they are wider and supposedly sticker. This is compared to 6yr old thrased 235 RS-R.
However, first session was wet, car had misfire, second session was dry and i shaved off some tenths on the PB without thinking I was going that fast, 3rd session I made a camber/damper adjustment which felt probably better in some ways, worse in others, but got held up in traffic on each hot lap then busted the car (minor).
There's definitely more in it, but I was not immediately blown away.
I also think I made the mistake of running too low hot pressures, around 34ish. They also seem like to firmer damper settings.
Can see the driver side cops it worse at this track, anti-clockwise with a highish speed continuous right hander.
I feel like I could have done the same thing on 255 RS-RR, which will last longer and cost less.
It was also a hotter day than my last PB, despite rain it was still 30 degrees.
Wont get another go til next year and by then will have made other changes to the car. Will aim for higher hot temps.
Dirt on the outside is from driving onto grass to load car.
Edited by ActionDan
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
