  • Replies 42
what gts-t vspec said :D
what do you do if you buy splitfire coilpacks cos stock coilpacks fry with a wolf, and then the wolf fries the splitfire coilpacks?
pls explain?
i have a wolf in mine, so far the only issue is the lack of tuners.
if its going to be cooking my coilpacks then that might explain my engine troubles atm...
I've had stock coil packs and split-fires running with my Wolf with no issues, as have most, seems that the tuner forgot to set the dwell time properly which has caused the issue. I do feel sorry for you, but it's not the products fault, its the person who set it up.
i wouldnt recommend getting a wolf in the first place they are completely not worth it.
Spoken like a true fool. Present facts b4 spinning 5hit. I have used this ecu in my car for the last 2.5yrs without any issues, apart from tune tweeks.
Yeah if you ask Lumpy (hyperdrive) nicely he may do it for u, just dont say who told u that he does a good job on them :)
I also agree the dwell time on the spark will make the coils crack along with a few other combinations but the wolf3d standard r33 ignition program is pretty well on the money, mes betting u may have a faulty loom.
Congratulations!! Your nomination for "Nob-end of the Month" has been accepted!
:kick:
I still use the Wolf with Great Results, on stock coils & splitfires! It now controls my 26 auto , using a 25 harness & stock 26 CAS....
Ewen , as for where to get it tuned , go to whoever your Happy with...just remember that no-one can tune out mechanical flaws like udersized exhaust housings , dodgy injectors etc...
Cheers
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
