Edited list below, just add what you do if you like in a post and i'll re-edit it to include you.
it just occured to me guys, there are a lot of us, locally, that are in a variety of different fields in the workforce.
how about a local thread for the members where we can post up what we do for a living. Im not suggesting mates rates or any kind of remuneration at all, but if any of us ever need advice on certain topics then we can ask local members for their help and advice.
e.g if we need info on bikes we know to ask Jayce, for info on electrical products we can ask (i forgot his board name but he works in electrics at domayne)
For learning on how to be the worlds greatest hunk we can ask Veilside etc....
we can have a list and it can be edited by the threads creator (most likely me) constantly so we can have a quick list for reference and help.
LIST:
VeilsideR33= Real estate agent
R31DET= ex car detailer and car artist, works for Ingrams Auto Electronics & Air conditioning
Supaflyskyline= electrician
R31_Silo2= Jeans west
4PKNUP= Target (the T is silent)
Terminal= Engineer
Amaru= Network Engineer
NJR 34GTT= IT Specialist with IBM
Bluprint= Web developer
Stevie= Public relations
Frink= ABC T.V and film and T.V guru
Oscar32= Child psychologist
OZR32GTR= IT Consultant
Leech_ = Network engineer
Sauce= Coles and studying 3D
Race_snooze= IT and ex Air-conditioning tech
skyGTRline= Southers ****
djhatton= Electrical section at domayne
bambinator= Doctor at Canberra Hospital
Anakha= Royal Australian Air Force
Yeti= Lawyer
Biancardi= Tiler
Marc2= Owner of dicount tyre service, Belconnen and Gunghalin and they are also authorised inspection stations, call 62515977 and ask for Mark. Fitter and turner, Mechanical & electrical engineer
SKYLVIA (Beau)= Electronics boutique
Matski= Commercial broadcaster
Noony= I.T security
LTSJayce= Athletes foot - Belconnen
Edited by Veilside R33
https://www.sau.com.au/forums/topic/74751-how-bout-an-sau-act-business-thread/
I work for the government.
I do admin side of building maintanence, for 8 buildings. So currently I will put my hand up for being a bum.
I am going to get a new job in October, and that will make me a mechanic, or at least try to be one
Finished my Engineering Degree at ANU last year, still looking for work as i took a bit of time off last summer
so does that mean you could engineer my car if it required it? this could be very handy indeed.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
