  • Replies 61
i have a auto r32 4 door....i've got a garrett gt30, fmic, pod down the front for cai and a 3 inch turbo back exhaust with no cat....
i made 226hp at the wheels (around 170kw) and 567nm of torque on 10 psi of boost.....in an auto its good because you don't loose boost during gear changes.... when my car was standard i raced a 2 door r32 even though it was a rolling start and he took off one car length ahead of me i won by around 3 car lengths....
the guy who does the work on my car owns a turbo torana with a stally and a 2 speed auto, he ran a 10.7 even after his fuel cut out the last 100m of the quarter...
he told me in an auto you will lose some power but might make up cos you won't lose boost through gear changes, my first changes at 8 grand so its a bit sluggish...
he told me in a manual i will feel the power more....and if i'm a good driver than i will do good down the quarter....but most ppl who want to go quick usually get an auto for the pure fact that boost is not lost through the gear changes....
I'm running my car next week so ill let you guys know how i do....
then ill do a before and after.....
:crazy:
man that is very cheap . did he explain why it was so cheap ? id be wondering .....
if you look around you can find a full manual conversion kit for under a grand
for an rb20det it was $900
The kit consists of: Gearbox & cross member & Tailshaft
Flywheel & Bolts
Clutch & bolts
Clutch & Brake Pedals
Clutch Master & Slave Cyl (pipe not cut)
Sandwich Plate
Body Dust Seal & Gearstick Boot
It contains everything to convert Auto To Manual.
if your in luck the clutch will be good, whoever does it will machine your flywheel aswell....but i would buy a new clutch.....
if you ask around for labour then you might get it cheaper than 2 grand all up....
also depending on how much your clutch costs....
and if you need help there's guys that have done the conversion and know how to perfect it just use the search and there's all the info you need....
Nah it didnt do anything on the dyno
But with the change of power to the shifts thats the power gain i were getting at compared to what a manual would lose they'd be very similar one would think now.
The best thing about autos though is no paying for clutches :)
But that isn't a change in power, its less time between shifts.
Depends which way you look at it.
With the standard valve bodies the gears will change slowly as to not jolt the car to make it a smooth ride.
With a modified torque/stall converter power is not restricted nor lost as its transfered alot faster.
*shrugs*
                                    Flywheel & Bolts
                                    Clutch & bolts
                                    Sandwich Plate
Could you point me in the direction of where to get one of these R32 GTS-t full manual conversion kits for 900?
  • 4 weeks later...
I have to agree with you though, the few who try and give me a run all apear in the rear view vission mirror.
haha
yor funny old man
i know who would win with an auto vs manual with same mods
id say most 200kw manuals would put pay to your 220kw auto
besides, who wants to drive an auto?
not me
i aint no taxi driver (even if i do have 4 doors)
I dare say the myth is based on the rough calculation of manual drivetrain losing 30%. I would guess it wouldn't be a long shot for an auto with a dodgy torque converter to bump the loss up to 40%. It's definaltely not 40% OVER a manual. that's just stoopid. why do all good drag cars run autos?
saying that, i'm a manual lover, you just dont "drive" an auto the way you do a manual. takes some of the skill out of it :P imo.
Please explain why a 220kw car should be beaten by a 200kw car? (Assuming similar suspension setups and equal driver skills)
Remember an auto can start on boost, unlike a manual, and it gets the benefit on more torque. There is a reason why almost all top levels of motor sport (drag, F1, rally) use auto boxes. You sound like just another 15yr old NOOB talking out of your ***.
mate, Formula 1 cars DO NOT use auto gear boxes. they are full manual up and down shift. Rally Cars DO NOT used auto gear boxes. V8 Super Cars DO NOT use auto gear boxes. Sports Sedans DO NOT use auto gear boxes. JGTC cars DO NOT use auto gearboxes. Other than drag racing no top level form of motor sport uses auto gearboxes.
Yes, auto's have an advantage at the drag strip. big deal. if you wanted a drag car I think you would be better off with an 800kg 13b turbo powered RX3 with a two speed. Any other form of motorsport and the only auto you will see is on the cars and trucks that are used to tow the race cars.
Formula 1 cars DO NOT use auto gear boxes...
:werd: alot of people mix up sequential manuals with autos. I call them automatic manuals ie the shift is automatic, but the box isn't; no torque converter, no planetary gear system, etc. If it has a torque converter it's an auto, if it dont, a manual. simple.
So 4 door sleeper, it would appear that YOU are the "15 yr old NOOB talking out of your ***" :)
I cited the drag strip argument to illustrate nothing more than that every auto in the world isn't utterly shite beside a manual. saying that, no full auto could ever emulate the insight of correct gear selection before reaching a corner etc, nor can it offer the weight set up into corners etc. I'll say it again, you dont DRIVE an auto, save fiddling with the throttle to try and get the f*&ker into the gear you want.
I'd even go out on a limb and say that drag racing is the only racing that an auto is suited for. Awesome for starts, cause all you have to think about is the right revs, then stomp it as soon as you're off the brakes. no clutch bite to worry about.
dont know much about manuals eh?
i can start on boost
i just rev up (to say 5000rpm)
let clutch out, revs drop slightly boost comes on straight away
voila, lauching on boost!
im sure if autos were the shit as you preach pops, that gtrs and other performance cars would come in auto as standard
they dont seem to though do they?
autos have their place though (drag cars, cars for people that are easily distracted and need two hands on the wheel at all times, taxis)
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
