just changed all of you from the last 2 pages who weren't done..
Hi guys, would you please change my nickname to 'Remix'
(Currently it is Remix-)
except you :tongue:
someone else has Remix, so you can't have it
  • 4 weeks later...
Hey there SAU'ers
Am interested in changing my name to Jeebus - (with the capital J) - as that's how i'm known on the 31 Club.
However, i do realise the name is taken, BUT, i looked at the user. and they signed up on 4th June 2005, and havn't been online since and they have no posts. Was wondering if you can just purge it or something... :
Here's the link to that user.
http://www.skylinesaustralia.com/forums/in...?showuser=20619
Thanks for that. PM if have any probs need more info or whatevz.
Cheers. :O
he's actually a very close friend of mine. I called him up and he was pretty upset about the whole idea. it took days for him to calm down
wtf do u want me to do?
uhh...days to calm down? i just posted this today? You knew i was going to post this days ahead! :D You read my mind, ohnoes!
but if so don't worry about it.....if it means so much to him.....
Edited by EVLR31
evlr31 why not contact that user via email or pm and ask if they are happy to give up the userid. if they are get them to contact a mod.
even tho dan is a nice guy I don't think he knows all 35,000 members personally
  • 3 weeks later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
