Hi, could I please have my username changed please, I'd like the following username:
LaBunta
hey, username change please!
to beau_32 please
thanks in advance
Username change to:
SmurFFF
Thanks!
Done :)
Hi guys, whenever you get a chance,
from GRK_GTR to [bRU2AL]
Thanks, no rush.
Done, but without the square brackets - the forum software won't let me use em in an account name, sorry!
  • 4 weeks later...
Can you pleas change my user name to
Lwood
Thanks,
Howdy. can i grab a name change to Rickford.
thanks bruh
Could i have my username changed to:
BakemonoRicer
Hi guys,
Can i please get my username changed to:
rorii
Reason: to match other forums
Cheers
All done!!
Back from holidays, back into the name changes :)
Could I get my user name changed to "Kintake"
Also could you not quote my Old username when replying, I'm trying to go undercover :thumbsup:
Thanks
Done! :ninja:
Can you change my user name to "Tommy Kaira RL" thanks
Done!
Hello,
Could i please get my name changed to:
Ant GTR-34A
Cheers,
Anthony
Name change to
Hadouken
Thanks :bunny:
hi could i can a name change to
XRB26X
thank you :)
Done!
Hi,
Could I please have my name changed to "THIRTY3"
Thanks
Name's taken, sorry mate :(
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
