  • 4 weeks later...
On 15/08/2016 at 7:54 PM, GTTR34 said:
Can I please request my username be changed to Downforce
I sold my R34 a long time ago. Cheers :)
On 16/08/2016 at 10:51 PM, TyresBro said:
Hi, can I please get my name changed to "TurboDoseBro". Thanks :banana:
Both done :)
  • Like 1
On 17/03/2016 at 5:24 PM, Revhead said:
Crazy/Crzy - if you can send me a PM or post in this thread using the other account I'll merge the two. I'm guessing you want to keep the account you've used above, as it's the one with the most posts (even though most of them are in here lol), it's just the name you want changed. Let me know if you want it the other way around.
Hi Arkan, the comment above still stands. I'm more than happy to help you merge your two accounts - just need you to log into the other one and send me a message to confirm it is indeed yours.
Arkan - this is the name change thread :) Easiest thing to do is for you to open your manual conversion thread and then click Report Post - that will notify the mods in the Victoria section that you would like them to have a look at it, they will decide whether it's appropriate to close or delete the thread. I've already done this for you this time around, just letting you know the option is there.
  • Like 1
  • 1 month later...
Can I please have my name changed to "Proximity Motorsport"
And where the hell do I click to make a damn donation!? I can not find or search it anywhere?
On 13/11/2016 at 7:34 PM, terrorstorm_ said:
Hey guys, can i get a change to gtrj by any chance?
Wasnt able to search through current members to see if the name is already taken.
Certainly :)
  • Like 1
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
