Hi guys,
I dunno how it happened but my car somehow made 230+rwkw at just 13 psi stock boost for hks2530.
Even the tuner was surprised. He now believes that with somemore tuning and upping the boost to 1.2 bars (around 17.5psi), we can make at least 250rwkw.
This was done on a dyno dynamics dyno!!!
I will post up pictures when I up the boost and fine tune the car.
Mods are HKS2530
GTR fuel pump
Power FC
3' turbo back with HKS split dump and race-cat
550cc Nismo injectors that somehow flow 565cc when flow-tested
Z32 afm
Hybrid FMIC
Splitfire di ignition coils
irridium sparks
I am now too scared to drive the car as even at stock boost, the car keeps burning the road when i dun want it to!
The tuner is still insisting on upping the boost to 1.2 bars though...what should I do. Will the car become even more undrivable then???
Dan
https://www.sau.com.au/forums/topic/75530-r33-gtst-makes-230rwkw-at-13psi/
  • Replies 41
If you can't control the power, either
a) Don't turn up the boost more!!!
B) Invest in a decent tyre / suspension setup to reduce traction loss
c) Drive by the throttle
With that kind of power though, I don't think you'll ever NOT get it to spin. Ahhh, how I wish I had your problems !!!! ;)
Dan
well done. I had 220rwkw with a similar setup except stock injectors, but the bottom end was fully rebuilt with forgies and GTR rods/ ACL race bearings so was good for running that consistently on the track.
I would recommend staying with what is comfortable, plus if the bottom end is stock it becomes more of a time bomb the longer you punish it, and will no doubt go bang at a moment most inconvenient. Also your clutch will be susceptible to burning out with hard accel through 3rd if you cane too hard. You decide what you want, not the tuner.
For the suspension I recommend a set of pineapples (120 plus fitting) which will allow greater traction. Also the stock suspension is crap so maybe some HD systems from UAS (1400ish) but order the softer springs (120 per pair or get them specced with the softer springs) for nicer road work if you don't track. Search for spring weights by Sydneykid who is our suspension Guru for examples. With this I was just chirping through second on the irregularities on the road on Dunlop 9000SP road tyres.
Hope that helps.
More boost!
But thats my answer to everything.
I'd get used to what you have then go for more :rofl: 2530 + rb25 = response. You'll have to start rolling on the throttle rather than stomping on it you lucky punk.
I'm running 240rwkw at 16psi at the moment and although my brand new tires managed to hold second without losing traction for 2 weeks, they're now starting to spin whenever boost comes on. 3rd gear can hold traction, but second no longer.
Once you start losing traction it just gets worse because the more traction you lose, the faster you lose tread and then you lose more traction blah blah. Just like a turbo boosting it creates a chain effect that gets worse and worse.
Good tires for the win!
Far too often I read a list of Skyline mods and I can't find anything that would improve the handling or brakes. Spend a small fortune on the engine and then can't use it. They don't have too much power, they have TOO LITTLE HANDLING.
Well Dan, it's time to balance up the equation, pop over to the suspension section for details.:cheers:
PS, aftermarket injectors always flow a little more than their rating (it's only 2.7% after all), nothing unusual there.
Thanks a lot guys for all yur answers....
I think I will up the boost to 1.2 bars then see how it goes. If I don't like it, I can simply turn the boost controller off. At least my PFC will be tuned to handle 1.2 bars when i turn the EBC back on.
Right?
The car is virtually permanently on boost. Even when it is not moving, u can sometimes hear the ball bearings still going for a while after the engine is off. Boost comes on very very hard suddenly and pins you in your seat with wheelspin just under 3000rpm.
So yes, I personally found that boost came on earlier and very much harder than the stock turbo.
i had to release my accelerator pedal to gain traction....i keep losing traction each time i overstep the acceleratiors. I am now practicing to be very friendly with the pedal.
Oh yes, I am surprise....my clutch is not slipping....how come? Its only a heavy duty 860kg organic!!!
I managed to drag the car up till 90km/h in 1st gear. That took me 4 seconds.
u must mean second, as first runs out way before 90 :)
and benl1981: i have a friend with same car as me apart from is have stock turbo and he has 2530, the 2530 is no laggier than stock, i would not say less laggy though, either way very very close.
the difference is when the 2530 comes on boost(with higher boost levels obviously contributing) it hits hard!!
in second/third gear in the 2530 equipped car u really gotta hang onto it with stock suspension so dan i know what u mean, and you really should change your springs/shocks and adjust camber.
Yo Aaron,
Im running a blitz dsbc type R. But the car is currently running on stock boost (apparently its 13 psi on my HKS2530) :D I see you are in SA as well!!! Me and a few other guys around our age of 20-24 meet up now and then. You should come join us mate!!!
just today, Sam, Duc and myself went for a drive in my car... and it reved cleanly to 9000rpm and wheelspins all the way in 1st and abit in 2nd....pity i forgot to get a picture of 3 R33s together in a row! You must come join us some time buddy. My hp is 0403671496
Dan
What boost controller are you running?
If you had say an AVC-R you could run just enough boost in each gear for the wheels not to spin/just spin.
or just don't plant it all the time :(
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
