Hi man,
I've been looking at peak figures on my HC and done a bit of search but can't find any info on the forum.
On city driving with ocassionla zippy accel and mix of traffic jams, my
Knock level tops out at 10, and water temp at 81C
Car is running HKS EVC@12psi,
FMIC,
stock injectors,
Bosch pump,
3" exhaust system,
tuned to 188.5rwkw (normal, NOT shootout) on Optimax.
1) Are those knock level sounds ok? That happen on fast acceleration with gear change around 4500rpm only. What's the knock level to start getting worry?
2) What's the maximum safe water temp? is 81C safe? At this temp reading on my HC, the needle on my factory water temp gauge is sitting halfway.
https://www.sau.com.au/forums/topic/77963-powerfc-monitored-values-how-safe/
Glad to hear it's ok...
Still some part of my questions haven't been answered yet...
What's the maximum safe knock level for RB25 that I should watch out for? 20? 30?
What's the maximum water temp to be considered safe? 100C?
Also one more thing, I noted the AFM voltage hovers around 1200-1300milliVolt
on idle... I thought the max stock AFM voltage is 1.5V (1500mV?) or 5V (5000mV)?
I remmeber reading it somewhere on this forum... but can't remember
1. hat's the maximum safe knock level for RB25 that I should watch out for? 20? 30?
2. What's the maximum water temp to be considered safe? 100C?
3. Also one more thing, I noted the AFM voltage hovers around 1200-1300milliVolt
My suggestions;
1. The dash warning is usually set around 40 or so
2. 85 degrees C is usually considered to be the target water temp for maximum power. Anything up to 105 degrees is not unusual, but around 80 to 90 is where it should run.
3. Max AFM voltage is ~5.1 volts
:rofl:
Im not sure about the 33s but for the 34s the dash light comes on once knock reaches above 60.
10 is hardly anything to be worried about.
if thats PFC your talking i think its adjustable ;)
81 water temp is great in traffic
My suggestions;
Punting it around furthermore I saw my top AFM voltage is 4.3volts.
So that's about 84.3% capacity at around 11 or 12 psi boost.
So using that as a rough guide is it correct to say that my AFM
would probably max out at about 14psi?
Injectors are only up to about 43% though.... so injectors still got some more life in it....
oooh robos 80-90 knock, id be going back to the tuner and get some timing pulled or something! im happy with my tune if i dont see over 30 knock... at the moment after a full on thrash i get about 28, and occasionally a 30.
as far as 10 knock is concerned, i think if let out a good fart when driving i might see that :rofl:
I reckon the knock read out is differant for every car, more of a guide than a measuring tool
Mine is all over the shop sometimes, I think my sensor is stuffed, either that or my exhaust or something hits the bottom of the car now and then and it picks that up. I remember when I was getting it tuned for a street meet ages ago, we pulled almost 6 degrees timing becasue the knock light was flashing, dropped 50rwkw, and it would still register knock. Coming back up slowly on the timing, we found it could take another 4 degree's (10 degrees above the minus 6) before it did knock, and let out a bit of a puff of unburnt fuel out the back, and the knock value stayed the same.
So I reckon its more of a guide than a measuring device, either that or mine is rooted!
That said, it has been quite handy on occasions, can tell the differance in knock levels when its got shit fuel in it, but there are greater things at play I think with my car....... something is making noise and it aint detonation!
Some times i get knock going upto 40 driving to the shops below 3000rpm. I also got 28 starting it up this morning, ouch
I might get a bit of knock and i always monitor it, but i've never heard it ping. I used to hear it ping with the stock cooler setup , but then i had no power FC to monitor the knock.
  • 1 year later...
The engine light can flash for 3 difference scenario's
1: knock going above the previously set level (setup on PFC laptop software)
2: The AFM voltage gets maxed out or close to maxing out
3: Injector duty goes higher then the set amount.
Usually the knocking is a very quick flash but this is programable within the Apexi power FC software. When dyno tuning i was told (from a mate who owns the dyno) he said to set the knock level when tuning to 40 and tune the car to show no more knock then that then set the warning to 60 so that the engine light flash's at 60 then he tells the owner of the car to back off the accelerator if he gets the warning light flashing - that way you know that knock is getting to a higher level for whatever reason and that something could be wrong....
If you get slow flash's of the engine light then usually it could be because the injector duty is maxing out (do a log max of the injector duty) or the AFM voltage is getting maxed out (you can log that as well in monitor)
Its hard to explain but say your tuner tunes the car to go to 90% duty cycle on the dyno and the car only runs 18psi of boost and he sets your injector warning to go off at 96% - your on a full on 4th gear hit in the freezing cold weather your turbo spools to 22psi - that would mean that the tune would go to a lower part of the map.. I know on my tune i changed the numbers that go lower on the map to a richer / fatter tune with less timing because IF the turbo spools enough load to go to those area's its going to need to run richer (or it may still be OK at the same numbers but you cant be sure because you have not tested it) - this area may go over the 96% injector duty that the warning was set to which will make the lights go off - it can also be running in a state where its very lean and can cause your engine to go kaboom! if you tune your car to go say 5psi higher then you plan on driving it on the street and set the warnings to go off at around those levels then you know its a bit more safer - thats the difference between a $200 touch and go power up tune compared to a $600 - $1000 tune where they pay attention to detail - you could save 3 hours of dyno time and not cost as much but you never know how good the tune actually is.
The same goes for the AFM voltage - if the map gets to the last line on the map then your going to get the warning because its maxed out - you could be only running 1psi more and its all OK or you could be running 10psi more which can cause issues. Some people run standard RB25 AFM's and tune the cars to run huge power levels and just tune the last line to run good safe mixtures to the maximum boost your boost controller is set to (never done it myself and dont know much at all about doing it this way as ive got a 90mm V8 AFM and at 16psi i still got more room on my load maps) this could be bad because you have to switch off the AFM warning. so next question is what happens if you get a big boost spike ? your answer is as good as anyones... (i aint 100% sure about this last comment as i have never done it that way before)
If your tuner uses the power FC software you can tell him to disable the warning for injector duty and AFM warnings all together so the engine light will only flash on knock to remove confusion because i know as well as as anyone when your on full noise you are trying to keep the car in a straight line and notice the light but dont pay attention to how its flashing as it could result in a accident or something...
So yeah when it comes to warning lights you need to totally understand how the power FC works and which warning you are seeing.
I guess it just pays to pay someone good decent money for a tune that you know that all these scenario's have been taken care for just for piece of mind - i spent 6 hours road tuning my car and when i put it on the dyno I was pretty impressed with how it was done.
hope this helps
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
