Mine squeek during low speed in and out of driveways and that sort of thing.
When the car's off the ground, you can wiggle the springs with your hands, but not when on teh ground.
  • Replies 378
Thats funny.. i'm not expert on shocks & springs but is it you setup the ride height to be so low so that when the car is off ground, the distance between the lower spring seat and the top mount is so huge that the spring is literally not compressed anymore? But yours is R34, mine's R33 so I dunno...
My problem was that with the standard circlip groove on the Koni's and King springs, the front was too low and the rear too high.
So, I bought and installed the Whiteline springs, and still, too low at the front and too high at the rear. So then we machined new grooves (the Koni dealer in Vermont) in both front and rear shocks and refitted. So the fronts were higher, there fore pre load on the springs, and the rear was lower, so no preload on the springs.
the heights though, are spot on. 345 front and 350 odd at the rear.
The squeeking sounds to be soming through the top of the shock, but that could just be the tranmitting of the sound through the steel.....
Stoopid cars.
Pete, sounds like the bush might be binding and squeaking on bumps. Is it front or rear? The rear of 34's is a yoke at the bottom right? Hard to say that they would be the culprit but I had my old ones do it at the front.
Do you have after market anti roll bars? Often the urethane bush can squeak with them.
SK,
Does this method of working out spring rates still hold true for progressive rate springs?
Cheers.
Yep, it's a bit more complex to calculate and I would need to know the coil spacing. I will post up a picture on how to do it over the weekend.
:P
PS. most so called "progressive rate" springs actually are simply designed to remain trapped at full droop. The soft rate is totally soaked up by the weight of the car, so there is no progression in the rate once the spring is installed and compressed.
Yeah, I've got the same problem, my front is too low till it can scrape the tyre on hard cornering... I dunno why but most ppl with Whiteline kit would have this "dive in" stance with the cars. I think I'm gonna ask my front ones to be re-adjust like yours, make it a bit higher so the car's sitting horizontal again...
I have seen this a few times lately, mostly due to people using GTR front shocks in GTST's. They are shorter. Or placing the lower spring seat in the wrong circlip groove.:(
Found an online calculator, it gets obtains values pretty close to what ur estimating SK.
http://www.proshocks.com/calcs/coilsprate.htm
Its from the website below, it has some good stuff on it...
http://www.martindalecenter.com/Calculator...rs1_3_Auto.html
Im going to measure my shocks tomorrow, their Trust coilovers, so no doubt the are going to be pretty stiff. Cant find any info about them on the internet, I dont think Trust make suspension anymore.
Rhett
Yup, hit me with it, SK. :P
These are King springs, lows, which I just got today. $250 for the 4, brand new from Repco, ordered yesterday. Most happy. :rofl: Replacing shitarse Pedders SportsRyder... which are saggy, imho.
Fronts: KDFL-101
ID Upper: 96mm
Lower: 85mm.
WD: 12mm
# Coils: 7.1
Rears: KDRL-61SP
ID Upper: 100mm
Lower: 90mm.
WD: 13mm.
# Coils 9.
Will put up the specs for the pedders when they come out tomorrow.
Edit: Tried that american calculator - roughly converted to inches, and got 244lb for the fronts and 164lb rears... which seems a little strange to me. Most setups have lower spring rate in the rear, but 80lb is a third of the fronts spring rate.
Oh well, shall take SK's calcs as canon, rather than my dodgy guesstimating.
  • 2 months later...
I don't suppose somebody could meaure a set of stock S13 Silvia springs for me? I am just currious to know what the stock rating is. I am about 15000miles from my car at the moment and can't seem to see the springs :)
Thanks guys!
Adrian
Oi Gary....
question for you :) what about these tien jobbies with the little cushion spring ? effect? or not...
They are called tender or helper springs, usually they are between 75 lbs per inch and 125 lbs per inch. They are mainly there to keep the main spring captive at full droop. They also give a modicum of inside wheel contact at places like the dipper. They totally collapse when the weight of the car is placed on the spring stack, that's why they are made of flat wire, so they neatly stack on top of each other.
You can live without them and simply limit the travel of the shock, so the main spring stays captive. But (there is always a but) that sometimes means there is not enough droop to get the wheels off when you jack the car up. Saw that happen on a Nissan SuperTourer, they limited the shock travel to save buying tender springs. Then they couldn't get the rear wheels on. :lol: :lol: :lol:
:) cheers :P
Yup, hit me with it, SK. :)
These are King springs, lows, which I just got today. $250 for the 4, brand new from Repco, ordered yesterday. Most happy. :P Replacing shitarse Pedders SportsRyder... which are saggy, imho.
Fronts: KDFL-101
ID Upper: 96mm
    Lower: 85mm.
WD:        12mm
# Coils: 7.1
Rears: KDRL-61SP
ID Upper: 100mm
    Lower: 90mm.
WD: 13mm.
# Coils 9.
Sorry I missed this post.
96/85 - 12 - 7.1 = 205 lbs per inch
100/90 - 13 - 9 = 175 lbs per inch
:) cheers ;)
SK would you mind calculating these please:
Top ID: 88mm
Bottom ID: 76mm
Thickness: 12mm
# turns: 10.125
Top ID: 98mm
Bottom ID: 66mm (yes it's a big difference!)
Thickness: 12mm
# turns: 7.0
Nismo springs for R32GTR
Thanks!
Mark
This is roughly my fronts - hard to do with them on the car. Not sure if its right
Coil OD = 70mm Bottom /95mm Top
Wire OD = 12.5 mm
# of Coils = 7.25 turns
Not sure about the Coil OD, i used string to go around the circumference(outside) then measured the string, then used:
Diam = Circum / pi to get the diam of the outside, then minus 25mm (2 x wire OD).
Top ID: 88mm
Bottom ID: 76mm
Thickness: 12mm
# turns: 10.125
Top ID: 98mm
Thickness: 12mm
# turns: 7.0
Thanks!
Mark
Hi Mark; results as follows;
88/76 X 12 X 10.125 = 170 lbs per inch
98/66 X 12 X 7 = 270 lbs per inch
:) Cheers :)
Wire OD = 12.5 mm
That means the 70mm/95mm is ID not OD?
No coil plant I know of makes 12.5mm spring steel wire, are you sure it's not 12 mm or 13 mm?
If it is 95 and 70 ID and 12.5 mm then;
95/70 X 12.5 X 7.25 = 300lbs per inch
:) cheers :)
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
