Yer but they could be still bad. U need to jack it up and grab the top and bottom of the wheel and wobble the wheel and see if it moves. If it dose u will need to replace. The only other thing I could think is it might be ur abs unit.
Also have a look at ur front drive shafts
Edited by whitenight27
Interesting today. Drove up the road and the left rear brake scrunched. Went back home and had a look. One pad was on the metal, not any pad material left, the other had 5mm of pad left .Both sliders were jambed solid. Luck had a set of pads in the cupboard.
My son came home at lunch time to do the job, he got back to work 15 mins late and the boss fired him. Words fail me.
At the risk of stating the obvious; your son's boss sounds like a galactic penis. :rolleyes:
Is there any recourse for him, as that sounds like unfair dismissal to me.
If I'd been fired every time I was late back from lunch as a young bloke; I'd have had quite a lot of jobs. :whistling:
Hopefully his next job won't see him under the thumb of a asshat like that guy.
Hey guys, as far as fitting brembos goes, im looking at going for 33gtr fronts, just wondering if it requires anymore than a dogbone and custom lines? And also the legality of braided brake lines. I also plan on running a larger rotor to suit.
if you have a s1 then gtr calipers and rotors should bolt up, no dogbones needed (unless you are referring to what brembos somtimes come with)
as for braided lines, just anything that is adr compliant will be fine, i think that may only be HEL
no dogbones/caliper adapters, or new brake lines required. there is a difference in the bolts for the calipers (the hub is 1 size larger than the brakes). Some people are concerned or make a spacer to sort that, I didn't and had no issues
I ran 32 gtr (same as 33 gtst) on the front of mine that way for years. cheap and easy upgrade
Yer to do with the bolts. I was going to use the stagea bolts will I be able to use them with the 32GTR calipers?
And what about the GTR hard lines will they work with the stageas soft lines?
And also was told there is a little bit in the caliper where the line bolts in that u need to remove if u use the stageas hard lines but do I need to still remove that if I use the GTR hard lines?
you my friend are a f*cking gun!
still undecided ATM but I can have 32gtr calipers (sumitomo's) for 50bux, 33gtst calipers pads rotors and lines for $300, or possibly 34 gtt setup for an amount I will find out tomorrow if he still has them..
I'm happy with the brakes but I need rotors and my only option is 500bux from dixcel so trying to see if there is a cheaper option
will definitely let you know as soon as I figure it out - thanks mate
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
