cheers lads! went with the 34 setup ($250 for callipers and pads), just need some rotors now.. i am rather lazy right at this point in time do i need to mess around with lines?? ;)
No, I have r34 front and back using the standard stag lines, the rears needed some different clips to attach but not sure exactly as it was done for me.
Go the 34 brakes on a s2 if you can
Someone asked about gtr rears, should be fine but you'll probably need tin snips to trim the backing plate/dust shield
thanks for that, anyone have any insight into upgrading the master cylinder going from stock s1 brakes, to 33 brembos?
I haven't tried that exact swap, but would not expect you need to change cylinders
I've run 33 gtr and g4 8 spots on my gtr without any bias issues. I've run 32 gtr and g4 8 spots on my stagea without any bias issues.
In the end, it is the total piston area that matters, the 32 and 33 gtr have about the same size pistons, the 8 spots have 8 very small pistons, and the stagea has 1 very large piston. you could always calculate the areas but I think you won't have an issue.
awesome, thanks heaps mate.
I changed my S1 brakes to GTT brakes with no issues. Later I put R32GTR brakes on the rear (essentially the same as GTT) and 330mm D2s on the front. I then put a BM57 master cylinder on which just means that with a larger area there is less pedal travel but more effort required. It would probably have been fine without the change.
sweet, if i have any issues with it, ill swap it out, but i figured it would be fine, just wanted to check with knowledgeable people.
Correct me if i'm wrong, but from what i have read online, 34 and 33 brembos are the same, and therefore gtr34 brembos should bolt up to my s1 all the same?
Edit: will a 324mm rear rotor and caliper off the later model gtr34's bolt up the same? or will i need dogbones to suit the bigger rotor?
Edited by HousewifE
trying to be a tightass and avoid spending 450 on dixcel rotors i spent 600 instead! :wacko:
250 - r34 gtt front callipers
80 - rotors and machining
130 - shim kit from nissan
140 - hpx pads and 1L brake fluid
Sorry to be a pain guys, I've read through countless pages of what Rotors will suit the S2 C34. From what I've gathered, the 34 GTT rotors are a direct fit, but I'm looking at going for some slotted rotors. I've read that shaving down the OD of DBA brakes for the 32GTR and 33GTST will work, but that information was posted a few years ago. Does anyone know of any direct replacement slotted disks for the S2?
Again sorry to be a pain, I need to get them replaced ASAP.
Thanks
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
