Just out of interest (for S2 AWD models) has anyone tried El Grand front rotors?
From the measurements I've found for the TE 52 these should in theory work?
290mm Diameter
28mm Thickness
49.2mm
68mm centre
  • 1 month later...
Ok all I have no pedal. I have a s1 just swapped the fronts for 32gtr. I used the stock stagea line and banjo bolt. I can bleed them no air is coming out but when the car is running there is no pedal at all unless u pump it up but wont hold it after. I have a hissing sound when u pump the pedal and the car will rev hunt. What could be the problem
Did you remove the restrictor in the banjo hole?
Perhaps the master cylinder is leaking inside the booster? Only because the revs hunt on application... Or the booster diaphragm might be leaking.
Nar dont see any leaks at all. Not dropping the fluid level and no fluid dropping from the calipers
It sounds like the master is your culprit in this situation mate. You may want to check the seals on the master before going any further.
If you don't clamp the lines before undoing the banjo from the stock callipers, there is a good chance you will get air in the ABS motor and these sort of issues will arise. I have bled the ABS lines myself, it just takes a lot longer as the air doesn't like going down hill.
  • 1 month later...
  • 4 weeks later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
