  • Replies 60
Posted Images
Mods:
Power FC
Boost @ 18.5
Garrett GT2560R
Tomei poncam 260/9.15 in/ex
nismo afm's
Sard 700 injectors
full exhaust
Think thats about it
I think its worth the money i spent :D
I will be at WSID today. See what sorta times I can pull
Good to see you got it all done with all the hasles you had .
Good luck at wsid tonight .
https://www.sau.com.au/forums/topic/83532-results-are-in/#findComment-1511437
Thanks guys
Big thanks to Jim @ CRD + Nathan at grey imports for the 'build'
Clutch was a custom 9 puk ceramic from UAS. Beautiful to drive on the street, and hopefully will handle the launches pretty well. Hopefully the gearbox or diff dont break :S
The boost isnt dialed in properly, thanks to my boost controller. So for the first couple of runs I will probably only be running 15 pound (stock actuators). These turbos are way bigger than the gt-ss's and is probably why they take so long to spool. Merli's/kababs car produces similar power at higher boost, but produces it much quicker .....
Once again thanks, and I hope the weather holds up :P
https://www.sau.com.au/forums/topic/83532-results-are-in/#findComment-1511988
How responsive is it compared to stock?
You have basically the same setup im going for except you're using 2560R's whereas im going for the HKS GT-SS's. I'm probably just gonna opt for 2xRB25 AFM's too.
You're running the stock fuel pump minus the low/high resistor right?
Overall a very nice result, grats!
https://www.sau.com.au/forums/topic/83532-results-are-in/#findComment-1512880
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
