The question of what wheel size fits what Skyline comes up so often I though this might be a good place to post your own wheel dimensions.
Just copy and fill in the table;
Skyline model =
Wheel diameter =
Wheel width =
Wheel offset =
Tyre size =
Modifications to fit =
One of mine as an example;
Skyline model = R32GTST
Wheel diameter = 17"
Wheel width = 8"
Wheel offset = 35
Tyre size = 245/45/17
Modifications to fit = remove the front inner plastic guards, roll rear lip slightly.
:( cheers :)
Edited by Sydneykid
  • Like 1
https://www.sau.com.au/forums/topic/84208-wheel-sizes-offsets-for-skylines/
Skyline model = R32 GTSt
Wheel width = 8"
Wheel offset = 32
Tyre size = 235/45
Modifications to fit = Roll lip
Wheel width = 9"
Wheel offset = 37
Tyre size = 255/40
Good work Sydneykid, now let's see all the R32 GT-R people posting!
Skyline model = R32 GT-R
Wheel diameter = 18 Inch
Wheel width = 9 Inch
Wheel offset = +24mm
Tyre size = 265/35/18
Modifications to fit = None
Wheel diameter = 18"
Wheel width = 10"
Wheel offset = +1mm ;)
Tyre size = cant remember probably 245 or 255
Modifications to fit = Roll & flare guards, stick out about 4cm from existing guards. needs a rear bar for them to look good... not good for defects..... almost needs widebody...
http://i2.photobucket.com/albums/y19/merli...12/IM000091.jpg
http://i2.photobucket.com/albums/y19/merli...12/IM000070.jpg
Wheel width = 10"
Wheel offset = +1mm  :)
Whoa dude.... ;)
Wheel width = 10"
Wheel offset = +1mm  :P
haha the rear looks like a AE86 drifter
Any idea how much clearance you have to the strut and also does it touch the inner guard lining on full lock?
Mine -
Skyline model = R33 GTS T
Wheel width = 8.5" front / 9.5" rears
Wheel offset = +30 front / +38 rears
Tyre size = 225/35R18 front / 255/30R18 rears
Modifications to fit = None. Car is on slightly lowered springs, very rarely will touch inner plastic guard when at full lock and hittin a pot hole at the same time <_< .
Edited by thommo
I think i've posted this link about 100 times or so in this section. But it's a very useful link.
http://marksink.com/tire_wheel_offset/offset.html
Use this to enter the offset and width of you current wheels, then input offsets of wheels you will like to buy and it'll tell you how far it'll stick out compared to your old rims, and how much clearance you'll have with the strut housing.
(maybe sk you should add this to the top post)
Skyline Model = BNR34 R34 GTR, BCNR33 R33 GTR
Wheel diameter = 18
Wheel width = 9.5JJ
Wheel offset = +12
Tyre size = 265
Modifications to fit = none
Wheel diameter = 18
Wheel width = 10JJ
Wheel offset = +20
Tyre size = 265+
Thanks for the link, the idea of the thread was to get the guys posting up their actual real world exeperiences all in one place. I don't know about anyone else but I have real problems with using calculated changes (one rim to another) to know whether or not the wheels will actually fit. An example, so it's 5mm in further, does that mean it will hit on the inner guard or not? Then there is the brake calliper clearance issues.
Thats why I wanted to have a whole heap of real world results for guys to look up.
:P cheers :)
Edited by Sydneykid
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
