Okay thanks. So the 255/40 is slightly smaller than the 235/45. Obviously this would have an effect on the speedo reading. would this still be a good option for the rear, or am i better off sticking to 235/45 all round? Intended use is track days, hillclimbs etc, with occasional street driving (ie. to and from the track)
Cheers.
hey guys scratchin my head on whether to grab a set of wheels. i want just a clean fitment basically flush with the stock guards with just a roll and lowered.
fronts are 8.5 +30 i know these will sit nice and flush
rears are 9.5 +40
now are these going to sit in to far that they will look complete odd and different when compared to the front or are we talking 5mm will make a match. or is 9.5 +30 what i really want to match the front? because i could live with 5mm but probably not 10.
basically there a good buy and been searching for a while
cheers coops
Cheers.
Go 225/40R18 and 255/35R18 for the same rolling diameter as stock :blink:
well going by that then im better off going 9 +22 all round so they sit +14 more fronts and +12 on the backs making it sit flush
being Te37s as well theyll have the concave look and not look so crap
agree?
9 +22 all round is a much better option as long as you have clearance to your struts :)
Skyline model = r34 gtt
Wheel diameter = 19inches
Wheel width = 8 front 9 rear
Wheel offset = +23 front +9 rear
Tyre size =215 front and 225 rear
Modifications to fit = everything lol, flare, roll, pump, remove inner plastics.
next set of rims will be even more ridiculous probs go bolt on flares
Hey Guys,,, :D
Sorry.. Bit of a noob when it comes to tyres etc
I'm chasing some tyres for an 18x10.5 rim (Rear)
Would someone be able to suggest what size tyre i should be chasing?
For an R34Gtt Running Full Cusco Coilovers and arms etc
Guards will be rolled...
Hey Guys,,, :domokun:
I just ordered 265/35R18s for 10.5 +30s on the rear of mine :(
235/40R18 is a good option for you as well.
Skyline model = R32 GTS-T
Wheel diameter = 17" enkei RPF1
Wheel width = 8.5" front and rear
Wheel offset = +30 front and rear
Tyre size =215/50/17 front and 225/45/17 rear
Modifications to fit = none. and the fronts rubbed the guards quite badly. didnt want to have to modify guards as i've seen other r32s with modified guards and they look terrible, unless converted to genuine GTR guards. so i got rid of these wheels lol
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
