Hey mate, thanks for the reply :)
Finally had a day free yesterday and chucked in the coilovers, nice and low now (although will be lowering fronts a bit more even :P). Yeah I've heard to avoid slip on spacers like the plague, lol.
Cheers for the info, will probably go down this route of just measuring now to figure out spacer size (any suggestions for not-shit-quality brands?). Yeah will probably have to look to getting guards rolled... as well as maybe some camber arms... just lowering it gave it some angle LOL. Now to wait for funds... :P
Most coilovers have around 2 deg camber built in. Nar mate I just got mine from justjap, and they set me back $350 for all round, and they have been fine so far and I drive pretty hard.
Hey guys..
Just been searching through a few pages but yet to come across any confirmation..
Looking to see if the following will fit an R34 GTR,
19 x 10.5 +22
Cheers
Did you ever get a conclusive answer? maybe you just jumped in a bought em?
Hi guys I'm new here just got a r33 s1 sedan and am looking at getting some 17x8 +5 for the fronts and 17x9 +10 rears anyone think these are too aggressive? Thanks in advance.
They will be pretty aggressive but I love the look of them. You will need a roll for sure and some camber to fit them under depending on the tire you want to run.
Have a look a few pages back I think around page 93 there is a photo of Hectics car
Well your rims will stick out about 6mm more
Hey guys just wondering, im about to order a set of Wolf S36's for my 33 gtst, any idea how they would fit if i was to order 18x9.5 +15 all round. im guessing some guard rolling, would there be anything else i have to worry about to get these to fit? Cheers
18x9.5 +15 with a 235/40 18. guard lip rolleds up 100%, camber is set at - .2 with whiteline camber arms, about 3mm off guard, will put camber to -1 before the next track day. front is -2.5 camber, hits guard liner, no big deal
Hey guys I'm trying to get a very flush fitment on my r32 4 door thinking 16x8.5+45 all round with 225/45 rubber anyone got anything similar I was running 17x9+15 all round but they sat a long way out looked awesome but trying for a different look now so want to run the smaller rim my car is as low as I could get my HSD's to go and has rolled guards all round
Any suggestions appreciated
Cheers
Did a search but only found close answers but not exact.
Looking at 19x8.5 +22 up front and 19x9.5 +22 down back. These are going on a r33 GTS-t.
Looking for an aggressive fitment without needing to flare guards so will this size and offset be ok?
Don't want it looking mexican but don't mind if wheels poke out a little bit.
Already have rolled guards and have camber arms.
Cheers.
These would be really agressive, a lot of poke i predict.
May wanna consider a more positive offset to save the hassle of possible defects and that.
If you want aggressive, do it :)
Cheers.
I've got 9.5 +23 front and 9.5 +20 rear on a 33 gtst, and don't have that much poke front and rear. Check out the "post your r33" thread if you want to see what that looks like.
Yeah you can, only reason I have bushes was to pull camber out so I could put power down easier, not to do with fitting the wheels
Lowering it on stock arms will give you negative camber, easily enough to tuck in these wheels
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
