Got R34 gtt with Bilstien slightly lowered coilovers
I want to get some Rota Grid R 17"
Plan to have 235s on front and 255s on the back
What offset/inch should i be looking at to be a nice fit ( no rolling )
http://www.rotawheels.com.au/wheels/rota-grid-r#!prettyPhoto
anything around +35 will be about right if you dont want to roll the guards etc. (tho it does depend on exactly the size of rim you intend to use.) 8.5 & 9?
Seriously though, dont hesitate to be open to rolling the rear guards. You can get some way nicer fitment and ride height if you do.
17x9.5+17 or 18x10+18
nope.
closest is 18x9+20 which will be a little sunken.
so options are:
18x9+20 with 10-20mm spacers
17x9.5+17 all round
17x9.5+28 fr and 17x9.5+17 r
17x9.5+17 fr and 18x10+18 r
18x10+38 fr and 18x10+18 r
18x10+ 18 all round
any of these will look good and pretty much all of these will require some form of fitment modifications unless you plan on running your car like an SUV
Does anyone have photos of how a 245/35 and a 255/35 sit on a 18x9.5 rim??
Can't decide which I want to run in terms of slight stretch. Pretty sure a 255 will just sit flush?
Need to know asap so I can supply one fitted to the body shop to pump my rear fenders to match.
255/35 Sits flush - have them on mine.
Hey guys, missed out on the buddy clubs! Now looking at some 17x9 +33 offset with 235/45/17 tyres? Also would these then fit over
the 324mm R33 GTR rotors (have the GKTech caliper Spacers for the 280mm disk)
Cheers!
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
