Got R34 gtt with Bilstien slightly lowered coilovers
I want to get some Rota Grid R 17"
Plan to have 235s on front and 255s on the back
What offset/inch should i be looking at to be a nice fit ( no rolling )
http://www.rotawheels.com.au/wheels/rota-grid-r#!prettyPhoto
anything around +35 will be about right if you dont want to roll the guards etc. (tho it does depend on exactly the size of rim you intend to use.) 8.5 & 9?
Seriously though, dont hesitate to be open to rolling the rear guards. You can get some way nicer fitment and ride height if you do.
17x9.5+17 or 18x10+18
nope.
closest is 18x9+20 which will be a little sunken.
so options are:
18x9+20 with 10-20mm spacers
17x9.5+17 all round
17x9.5+28 fr and 17x9.5+17 r
17x9.5+17 fr and 18x10+18 r
18x10+38 fr and 18x10+18 r
18x10+ 18 all round
any of these will look good and pretty much all of these will require some form of fitment modifications unless you plan on running your car like an SUV
Does anyone have photos of how a 245/35 and a 255/35 sit on a 18x9.5 rim??
Can't decide which I want to run in terms of slight stretch. Pretty sure a 255 will just sit flush?
Need to know asap so I can supply one fitted to the body shop to pump my rear fenders to match.
255/35 Sits flush - have them on mine.
Hey guys, missed out on the buddy clubs! Now looking at some 17x9 +33 offset with 235/45/17 tyres? Also would these then fit over
the 324mm R33 GTR rotors (have the GKTech caliper Spacers for the 280mm disk)
Cheers!
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
