they can however it's better to remove them as the bolts that hold them in are pretty good as catching tyres if the car is low
also clearace is an issue... my tyres would hit the metal above on occasion so liners would have been destroyed anyway...
also it's a good idea to jimmy up something to hold the cables out of the way in the right front arch
this is true, Mine rubs the bolts occasionally coming in and out of driveways.
My thoughts too, but apparently not. While hard driving the lock seldom goes as far as while entering driveways. and the camber change is never that much on a road or track as it is coming up driveways.
Hey guys, Just had a quick read through this thread but couldn't really find anything about wheels for an r32 GTS-T coupe type M
- The guards aren't rolled or anything to my knowledge..
- I know nothing about offset/width and all that
I'm seeking advice on a nice sized wheel. I want 17" or might go 18"
The wheels on the car are ArchWheels.. So seedy they look like a spider web (bought with them on the car)
I have no idea what size they are, pretty sure they're 17's but the car is 110km away at my grandparents ready for a little makeover
So if you could give me some nice sizes with the specs etc.
Cheers Zane.
Anyone know the backspacing for standard r32 gtst wheels?
It looks like about 4 1/2 inches but im not sure.
Im liking these http://www.summitracing.com/parts/crr-3978912/overview/
But im looking at how very close the hicas knuckle is.
I know they are steel, but the only other ones i really like are about $4000 (gold fabulous racing)
Anyone have any experience with the follow size wheels on a R34 GTT?
F - 18*9+22 running 245//35//18 rubber
R - 18*10+30 with 265//35//18 rubber
I am looking at getting some wheels for my GTT, currently running stock suspensions (planning on lowering after I find the right wheels.)
I'm hoping for the wheels to sit as flush as possible with the guards. Would also like to avoid stretching rubber.
I'm prepared to roll guards when I lower the car, but I'm wondering if any further work would be required??
Cheers!
Anyone know if a 275 tyre would have a bludge or straight side wall with 9.5 inch rims. Any pics would be appreaciated
They sit straight on the rims! Look in my build thread somewhere and you will find a pic! Too lazy to go find it for you!
I am in the market for new rims for my r33 gts4 and have narrowed the selection down to two designs, work vs-xx or meister s1
in either 18x9 +15 or 18x9.5 +20, both sizes and offsets should fit ok but I'm not 100% sure.
easy.
Thoughts on this size?
Rota Grids (concave version)
18x10 +35 offset
with 235-40-R18 and 245-40-R18 tyres
With the old tape measure there will be a bit of poke on the front, but im more concerned with what it might
touch under the arches!?!
http://www.willtheyfit.com/index.php?width=215&aspect=55&diameter=16&wheelwidth=6.5&offset=40&width2=235&aspect2=40&diameter2=18&wheelwidth2=10&offset2=35&Submit=Submit
^with the 235 tyres for the front
Cheers guys!
18x10 +38 on the rear will be fine. Go 18x9 +30 on the front
Cheers!
You need to look back a few pages, try to find my post and pictures.
Short answer: Perfect. Get coilovers and slam it. I would change rubber to 225/45 and 245/45 personally for more low.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
