Looking at getting wolf s1p will 18x10 + 35 fit rear? Otherwise this
Skyline model = r33 gtst
Wheel diameter = 18
Wheel width = 9
Wheel offset = +27
Tyre size = 235 40
Modifications to fit = ????
10+35 SHOULD fit rear, I had 10.5+30 and it fit no issues.
Other than that, the 9+27 would be near on perfect.
Looking for some ideas on what size tyre I should run on my new wheels? These are on a 33 gtst.
Current specs are: Front: 18x8.5+35 235/40 Rear: 18x9+35 265/35.
With my mildly rolled guards they fit easily 15-20mm inside the guards and I can fit my almost my whole hand in and around them in the guard and get pretty much no scrub at full lock or anything but I'm not sure if I kept the same tyre sizes it would clear everything easily and not scrub like all shit. My new wheels are 18x9+20 all round so a fair bit more agressive offset but nothing crazy. I don't want much stretch and would like the largest and most practical tyre sizes I can fit without more guard work. Any help is much appreciated! cheers.
18x9+20 with 245/40 all round :)
Rolled guards, front upper control arms to help tuck it in. Bit of scrubbing otherwise
Edited by dontyellpl0x
  • Like 2
My R33 GTR on Work emotion D9r ... got them back in October on the 12th, just been lazy and havent up loaded anything.
Work Emotion D9R 18x10.5 +15
Federal RSR Semi slicks 265/35/r18
Hnngg.
Edited by sleptema
  • Like 1
Hey guys I'm looking at buying a set of enkei RPF01's for my r32 gtst, I'm just wondering wether 18x9.5 +15 fronts and 18x10.5 +15 rears would fit
Not a chance without work. Well, they'll fit... drivability is probably not great...
My 18x9.5 RPF1's all round on the BNR32 barely fit as width goes.
I can't remember if the GTST fronts are same but you'll need to run 245's if you want to not rub the guard liner.
You'd have 1inch sticking out at the rears with 10.5's, not even camber alone with get that back..
Lol this guy ^
What look do you want and how much work ate you prepared to do?
If you run 225 and 245 you will easily make it with camber and a big guard roll.
If you are going for something that will still grip then expect to pull guards a fair amount
Guard liners won't be an issue as they will have to be removed anyway
Hey can you guys help me out I have a 33 gtst and I'm looking to go different wheels, just wondering if I can 18" 8.5 +30 on the front and 18" 9.5 +38 on the back? Or should I just go same width front and rear, if so should I go 8.5 or 9.5 all round???
That's exactly what my old wheels were and it fit fine. 9.5+38 265/35 on the rear and a 8.5+30 235/40 on the front.
  • Like 1
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
