Looking at getting wolf s1p will 18x10 + 35 fit rear? Otherwise this
Skyline model = r33 gtst
Wheel diameter = 18
Wheel width = 9
Wheel offset = +27
Tyre size = 235 40
Modifications to fit = ????
10+35 SHOULD fit rear, I had 10.5+30 and it fit no issues.
Other than that, the 9+27 would be near on perfect.
Looking for some ideas on what size tyre I should run on my new wheels? These are on a 33 gtst.
Current specs are: Front: 18x8.5+35 235/40 Rear: 18x9+35 265/35.
With my mildly rolled guards they fit easily 15-20mm inside the guards and I can fit my almost my whole hand in and around them in the guard and get pretty much no scrub at full lock or anything but I'm not sure if I kept the same tyre sizes it would clear everything easily and not scrub like all shit. My new wheels are 18x9+20 all round so a fair bit more agressive offset but nothing crazy. I don't want much stretch and would like the largest and most practical tyre sizes I can fit without more guard work. Any help is much appreciated! cheers.
18x9+20 with 245/40 all round :)
Rolled guards, front upper control arms to help tuck it in. Bit of scrubbing otherwise
Edited by dontyellpl0x
  • Like 2
My R33 GTR on Work emotion D9r ... got them back in October on the 12th, just been lazy and havent up loaded anything.
Work Emotion D9R 18x10.5 +15
Federal RSR Semi slicks 265/35/r18
Hnngg.
Edited by sleptema
  • Like 1
Hey guys I'm looking at buying a set of enkei RPF01's for my r32 gtst, I'm just wondering wether 18x9.5 +15 fronts and 18x10.5 +15 rears would fit
Not a chance without work. Well, they'll fit... drivability is probably not great...
My 18x9.5 RPF1's all round on the BNR32 barely fit as width goes.
I can't remember if the GTST fronts are same but you'll need to run 245's if you want to not rub the guard liner.
You'd have 1inch sticking out at the rears with 10.5's, not even camber alone with get that back..
Lol this guy ^
What look do you want and how much work ate you prepared to do?
If you run 225 and 245 you will easily make it with camber and a big guard roll.
If you are going for something that will still grip then expect to pull guards a fair amount
Guard liners won't be an issue as they will have to be removed anyway
Hey can you guys help me out I have a 33 gtst and I'm looking to go different wheels, just wondering if I can 18" 8.5 +30 on the front and 18" 9.5 +38 on the back? Or should I just go same width front and rear, if so should I go 8.5 or 9.5 all round???
That's exactly what my old wheels were and it fit fine. 9.5+38 265/35 on the rear and a 8.5+30 235/40 on the front.
  • Like 1
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
