It's barely a stretch. 245 is the legal minimum and 235 is within minimum spec for most tyre manufacturers.
At 9.5+20 of it's low you either have to stretch your tyres or your guards....
Yeah the front guards are already rolled and the car is sitting only a tiny bit lower than stock height (nismo s tune suspension)
I might trial fit 235 like you suggested, and maybe 255 if that fits easy
I have 225 on my 9.5+20. Main reason being that if you have 255 on there, you will not be able to lower it much less than factory. I have dropped mine about 20mm, and it sits on the tyre very nicely. 9.5+20 is a very aggressive rim, and while I wouldn't have it any other way, it's cop bait for sure. I recently get a defect notice because of this. That being said, as soon as the farker is off, I will be slamming it again.
Ahh bollocks, i thought 9.5+20 only stuck out a tiny bit (from pics I've seen), and that cops wouldn't bother me too much. Do you have any pics of how much yours sticks out?
Edit: seen your car before actually haha looks mad! Never realised it was yours
Edited by tiddyd
  • Like 1
Hey guys,
tossing up between these two sets of wheels:
Rays Grams Light 57F-Pro
19x8 +17
19x9.5 +17
or
Work XT-7
18x8.5 +28
18x9.5 +32
I know the XT7's won't be a problem but the rear rays will be for an R34 GTT. From my research I think the 9.5+17 should sit about the same as a 10.5 +30 which means they will poke a bit. I have Tein coilovers so there is some natural camber on my car already. Could I get away with no guard work for the Rays? The fronts should sit the same as a 9 +30 wheel. I like both wheels a lot but the dish on the Rays looks too good.
Cheers
Both of those will look terrible in thise sizes. Im not gonna sugar coat it as it's a lot of coin to waste.
Your rears will poke by some ~10mm on the 19's and sit in about the same on the 18's.
Your fronts will be sunken like an itallian cruise liner on both.
18's look better than 19's on that car (in that style of rim). 19's would be for more of a VIP thang.
If you want flush on a gtt look at 18x9.5+25ish front AND rear and run 235/40
Can someone help me find the perfect sizing for R34 GTT?
I'm after TE37 17's But unsure of what offset and size.
I will roll my guards.
I will be ordering from Jesse Streeter.
Hoping for it to look really aggressive.. like a GTR.
Thinking > 17x9 +22 offset..
Are spacers required?
http://gripshiftslide.com/photos/FORUMSHINE/31.jpg
Thanks
Edited by MariahCarey
Hi looking for some help on new wheels/tyres for my R33 GTR.
Would either of these dimensions fit with no mods (18x9.5 + 18 or 18x10 +18)? Planning on running 265/35/18. Would one fit better than the other? The car is lowered on bilstein coilovers.
I don't want it to look 'stretched' or 'poked' or 'slammed' just want to fill the guards nicely and lower the car sensibly and make it look tough. Thanks for your help. If anyone has any pics I would really appreciate it.
Hi guys,
I've just bought a 32 GTR and looking to get as much rubber as I can under the guards. I'm aware 18x10 +20 is near on optimum. Toying with the idea of going 18x10.5 +25. Anyone had any experience with that size? Not adverse to rolling the guards, more concerned about strut clearance and front turning clearance.
Any feedback appreciated.
18x9.5 + 18 with 265/35/18 is perfect
for a 10' rim i would go +20
He has an R33, so +18 is fine. I'd run 275-285 on the 10" though (I have 275/35/18 on mine).
But no mods, 9.5+18 with 265 tyres is a safe bet.
Thanks for your input guys. Much appreciated.
  • 3 weeks later...
ok i feel like im asking a stupid question but i cant quite work it out.
for a 32 gtr regarding staggered offsets,
i know everyone sais it will trip the atessa system.
how sensitive is it?
i want to maby run say 18X9 and 18X10 for instance (offset asside) if i run the same size tire on each will it be ok? or do i need to run wider tires to negate the tire stretch?
i understand the rolling diametre needs to be the same for obvious reasons for the 4x4 system, but how does the wheel width stuff it up?
yes yes, but can anyone answer the question?
if rolling diameter is the same, why do staggered wheels mess with the 4wd system?
is it really sensitive enough to have tire shape deformed by stretching or different tire widths change the rolling diameter? surly not.
Yes it is. Deflate one of your tyres to 20-25psi and observe the changes (if your ATTESA is working correctly).
As long as the rolling diameters are almost identical, you *should* be okay. E.g. 245/40 front and 275/35 rear.
Or you can run 275/35/18 all round :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
