Found this...
18x9.5 +15
Not what i'd call a "dick load", some camber and you'd get em under. Depends what you're after exactly. RPF1's are the shit though, and worth the effort. They look good on anything.
Theres more here in this thread.
http://www.sau.com.au/forums/topic/372204-r32-gtst-fitment-pics-please/
Edited by R31 drift pig
And you forgot the part where he says it doesn't have camber arms etc, so some camber and suddenly they're not sticking out.
2.5 - 3 degrees up front and a smidge in the back and done. Dynamic camber will take care of the rest.
Be pretty silly to put them on and not put in a decent alignment.
Cheers for the replies.
Wanted to go 18s in the RPF1s but dont think they have anything that will fit the 32 or without them going ummm concave out wards if that makes sense. feel they look ugly going that way
So my choice, i think my only choice are 17x9 +22 all round?
Will these be ok? any other choices?
Skyline model = R32 GTR
Wheel diameter = 17
Wheel width =9
Wheel offset =+22 TE37
Tyre size =255/40/17 nankang ultra sport NS II
Modifications to fit = none
rear:
front: kind of sunk in
*Looks 10x better than above setup.
Wheel diameter = 18
Wheel width =9.5
Wheel offset =+12 Advan RG
Tyre size =265/35/18 Advan AD08R
Modifications to fit = light fender roll. Just the lips, nothing more. A few degrees of camber could also maybe fix the problem. I am not sure of my current specs.
Front:
Rear: Perfectly flush
Edited by JTCC
  • Like 1
  • 3 weeks later...
Recently came across this car while browsing on a used car trading website in HK. I understand the pictiure is kinda grainy, but could anyone make out the approx wheel and tire specs on the car? Also does anyone know what brand of wheel it is. Looks good imo. Thanks!
Edited by roy2535
Hey guys I've got my mind set on Enkei's RPF1's in 18's. I'm having trouble finding what offset I need and I don't want to roll the rear guards. Also I want the correct tyre sizes because I want a functional setup.
It's asking for a lot, but I want it to be perfect.
Edit: 18x9's all round be asking too much?
Edited by Dan93
Damn no good. Those tyres will be too skinny.
At the moment it's got 17x8.5's on the front with 235's I think and 17x9's on the rear with 255's.
No idea on offset, but you can get a slightly angled finger in between the rear tyre and guard.
It all comes down to usage/what you want.
End of the day you can get a better 235/40/18 that will grip more than a 255 for the same price due to the common size discount.
I ran 235 NT05's, low with a decent sussy setup (6/8 coils, camber bushes, pineapples, sways, hicas lock) and had traction right through second with 330rwkw
I don't like the idea of a tyre being smaller than it should be. I obviously want it to look good and tyre fitment needs to be spot on. I'm not worried about paying more for a wider tyre.
What kind of power are we talking?
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
