  • 4 weeks later...
Skyline model: R34 Gtt
Wheel diameter: 18"
Wheel width: 9" Front and back
Wheel offset: +22 Front and back
Tyre size: 235/40/18
Modifications to fit: Front guards are rolled, but not needed, no scrub at all, and no camber.
Perfect fitment for a gtt imo. So happy with them
  • Like 2
Hey guys need some assistance...
Looking at running these on a 32 GTR Vspec in one of the below sizes.. Will I have any issues? Can run negative camber although not looking to roll guards..
19x9.5J 114.3 +50 / +30
19x10.5J 114.3 +25 / +15
Edited by GRKGTR
They will look aids in that size. Stick to 18's
9.5+30 will be sunken
10.5+25 is the best option there and will work but need a lip probably
But yeh... 18's
  • Like 1
But yeh... 18's
They are also available as 10.5 +15 in 18s
Trying to achieve this look although with a bit more dish.. Reason I was looking at 19s is so I don't have to have the car at an illegal height to fill guards.
http://www.motormag.com.au/media/2699068/nismo-festival-4.jpg
