  • 3 months later...
  • Replies 74
Awesome - Got a dyno done on my car and the AFR stays at like 14ish from 1k rpm to 6k rpm >_<
So been taking it easy and saving for a fuel pump but it's hard when you just get your annual insurance bill... anyway I think I might go for this tomei pump too looks/sounds better then the others I have heard about.
Had a read through this and I think I can install it myself - well done guys and thanks!
  • 3 weeks later...
  • 5 months later...
  • 1 month later...
yes easy to fit.. so I thought.. I can hear the pump (nismo) priming (or trying to) but it's bloody loud and doesn't sound right, sounds far to high pitched or something. Car doesn't start, so I assume it's not feeding fuel, but when I disconnected the hoses again after a little while the line was full of fuel. Disconnecting the line going back to the pump released a lot of air (from the tank I think).
Any one have any ideas? Could I just have the hoses connected the wrong way around or something? If that even matters.
  • 2 months later...
  • 4 weeks later...
Well i installed my walbro today (from sliding performance) anyway had a bit of trouble with the fuel pump isolator rubber that goes on the bottom, its to small to hold the pump in place on the standard bracket, so i modified the standard one by cutting it to fit the fuel pump as best i could, it sits slightly adjar bcoz of the filter sock that comes with this pump doesnt go down where the standard one goes it goes out to the side instead. i just want to know with this not being as deep as the standard one will i have trouble with fuel pick up etc?
also i zip tied the pump into place to stop it from moving. so it shouldnt slip off the bracket at all now. sounds a bit dodgey but we made sure it was sitting as close to stock as possible.
other then these problems it was all pretty straight forward.
id like to hear a few more story's of people who have installed walbro pumps to see if they had any problems with there installs?
Cheers
Daz
Cheers
Daz
I did the walbro pump install, mine fitted fine with the smaller rubber bottom it came with. And the factory filter fits onto the walbro pump so you don't have fuel pick up problems when running low on gas. I found the walbro pump to be a very easy replacement.
the small rubber bottom i got doesnt fit tight like the standard one, the half round shape it fits into wasnt the same size on mine. so i just modified the standard one, seems to work just as good anyway, had no problems with it. pumps fine.
I installed Walbro, just had a good look at how std pump sat on bracket and then put Walbro in same place (slightly slower on bracket) using the rubber/foam sleeve it came with and 2 x steel threaded clamps (big hose clamps), used the filter sock from the std pump I think.
Changed it with fuel guage needle on empty line - started fine (on 2nd key turn) and hasn't missed a beat since, and I like to run to fuel light. (Yep change fuel filters regularly)
You can hear the pump if you listen for it and can hear the pitch change from idle voltage to on throttle voltage, certainly not an isue though, nice to know it's working.
FWIW: Nowhere near as loud as Bosch GTR pump in 200SX.
(If you use a Walbro they are very sensitive to voltage vs flow rate) there is a graph somwhere about fuel pump comparison for a Supra (US site), google it.
Edited by simpletool
  • 3 months later...
After reading the whole thread from page 1 to page 3, i can assume that the Nismo Fuel pump (which is identical to the Tomei one) WILL work with the stock Fuel regulator AND Stock injectors AND i do not need to install the included pressure valve .
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
