  • Replies 714
Posted Images
+2mm = toe in and -2mm = toe out doesent it???
Not in my race team.
The numbers refer to the toe (ie; front of the tyre)
Not the heel (ie; rear of the tyre)
-2 mm toe means the toes are closer together (ie; the distance is 2 mm less between the toes than it is between the heels)
+2mm toe means the toes are further appart (ie; the distance is 2 mm more between the toes than it is between the heels)
:) cheers :)
PS; no, I don't have a foot fettish
Edited by Sydneykid
Cheers Sydneykid got it all sorted
If anyone is after the subframe alignment part number - KCA349 for their r33-gst-t let me know as I ordered the part without realising I already had a different make installed on the car. I will sell it for $100 with delivery, rrp is $124 + delivery. It is still brand new and hasent been used or packet opened.
Hi SK,
Very interested in purchasing the kit...
I also thought I'd mention that I think it's great that you've gone to the trouble of using your expertise for the benefit of the group :)
Just wanted to ask...
My suspension set up is currently stock and my car is predominantly a street car, although it does see action at WSID every now and then.
Would you still recommend that this kit is suitable for my needs, or would you recommend something different that may benefit me at the drags whilst still giving me good handling on the street?
Interested to hear your feedback.
Brenden.
Hi SK,
I also thought I'd mention that I think it's great that you've gone to the trouble of using your expertise for the benefit of the group :P
Brenden.
Hi Brenden, I get a lot out of the forum and this is one way I can put some back. Plus I might get some more engineering work as the Group Buy is selling quite a few kits. Showing the potential for a properly engineered kit.
I have designed this kit for primerily road use, it does quite well on the track (circuit and drag) and is much better than the standard stuff. The rear spring rate is not very stiff, doesn't need to be, so it works OK for launches (road and track). If you only go to the drags once or twice a year then this is best compromise, including the recommended settings. If you go a little more often (say 3 or 4 times a year) then there are a few alignment changes that will help.
1. Set the rear subframe alignment bushes for maximum squat. That's the small split bushes above the front mounts of the sub frame and the small (non split) bushes below the rear mounts of the sub frame.
2. Set the rear camber at posititive 0.25 degrees, the recommended setting is 0.5 degrees negative. This gives less dynamic negative camber when the rear squats on launch and thus increases the tyre contact patch.
3. Set the adjustable rear stabiliser bar on minimum stiffness, this limits any transfer of vertical forces from one rear wheel to the other.
If you intend to go to the drags more than 10 times a year, or are serious about setting a time and don't mind compromising the road handling, then hang out a couple of weeks for the drag kit that I am currently working on.
:) cheers :)
Edited by Sydneykid
I got my full kit delivered today thanks Gary (SydneyKid) & Jamex Australia.
Everyone who's worried about putting money down first, I'll put it clearly:
DONT WORRY -- PERFECT TRANSACTION, PERFECT COMMUNICATION, VERY FAST SHIPMENT TO VICTORIA &
REMEMBER - GARY WILL LOOK AFTER YOU!
I am more than happy with the kit & it is going on the car Friday at 8AM. I will let everyone know how it goes.
Please everyone help yourselves & other members
- SUPPORT & USE GROUP BUYS
Once again,
THANKS
SYDNEYKID! TOP WORK :(:):)
Thanks for the advice SK :)
I'll definately consider buying and installing the kit (with the settings you mentioned above) in the next month once I've finished my turbo upgrade.
Appreciate the help :)
I know it sounds like I am pushing, but there are only a limited number of Bilsteins available. When they run out I wil have to close the Group Buy. Bilstein (Germany) won't make Skyline shocks just for Australia, we don't order enough to make it worthwhile them doing a production run. So we have to wait until Japan orders. Nobody knows how long that will take, could be months, might be tomorrow. Plus Bilstein production scheduling is currently 3 to 5 months ahead. So that's the minimum anyway.
If the Bilstein distributor gets enough shocks delivered out of the production run. then I might be able to convince them to do it again. But if they only get a handfull, then they won't want to offer them at a cheap price. It's a kit deal, so I don't think I will be able to get Whiteline on board without Bilstein.
The bottom line, if you want a set, then order them now, I would much rather SAU guys get them than outsiders. Jamex will hold them on deposit ($100 a shock).
:) cheers :)
Hi,
The PM system doesn't seem to be working now so I'll have to post here.
I've paid for my order for shocks and springs and the receipt no. is 537791. I'll send you my full PM when the system is working again.
Regards,
Ben
Hi,
Regards,
Ben
PM has been received and the order processed. Thanks for supporting the Group Buy.
:O cheers :)
Hi Sydney Kid, I was looking at getting the "works kit" for my R33, I was just trying to figure out what i need from you list for it to be the same as or similar to the standard works pack, Is it two sets of shocks two sets of springs, 2 stabilizer bars and one of everything else?? Sorry if this is a dumb question but I really dont know waht I am looking at once I get past the springs and shocks!
PM Sent
:P cheers :D
Update: I was advised of shipment Tuesday and Delivery occured Wednesday. No sweat on the delay as I already knew some items needed to be manufactured. A couple of items still to come but I now have the important items to smooth out my ride.
How am I feeling? Ecstatic!! What a great shock/spring setup. Massive increase in front grip on bumpy corners.
hay SK,
how much neg camber can you tune out of the rear tyres with the offset bushes?
if you have a car that is diving in to the corners too hard with a fare bit of understeer which swaybar will help tune some of this out Frount or Rear?
cheers,
Boz
hay SK,
cheers,
Boz
The standard adjuster is 0.3 degrees, the outer upper adjuster is almost 1.0 degree, the inner upper adjuster is 0.75 degrees. The recommended settings are 0.5 to 1.0 degrees. So if you have 3.5 degrees now you should be able to get it withing the recommended range. If you need more adjustment than that, then I STRONGLY suggest you raise it up to a more sensible height. It must be below 320 mm centre of wheel to guard, which is far too low for good handling or power.
As well as the adjustment, there is also the lower compliance of the polyurethane bushes to consider. This means less dynamic camber change (under load) which can add another 1.5 to 2.5 degrees to the static readings with the old/well used standard bushes. Most of this (dynamic camber change) is eliminated with the new polyurethane bushes.
Hope that answered your question.
:P cheers :D
:) cheers :)
Garry
are the KCA347 bushes the ones that i need?
did you have a think about my previous question about the swaybars? it is for my brothers GT4.
Cheers,
Boz
Garry
Cheers,
Boz
HiBoz, yep the KCA347 fits all R32, R33 and R34 models. If you do actually need both inner and outer adjusters to get the camber right, then make sure you order 2 X kits.
Sorry, I missed the swaybar question before. Usually increasing the rear anti roll reduces the understeer, so that is where I would start. Increasing the caster also helps a lot.
:D cheers :)
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
