Hi, Ive just got this question that i would like to know what peolpe think.
Over the last few weeks ive been pouring ALOT of money into my skyline r33.
And its still SLOW. My mate has a Sik Mazda Rx3 rotary. It is SOOOO fast and i just cant help but feel so sad when i drive my little skyline :huh:
Its the best rotar and its 10 times as quick a smy skyline for 10 times as less money spent.
So im thinking of selling my skyline and buying a rotary powered car.
CHeers Rodney.
  • Replies 40
how much have you spent? what year is your car and what year is the rotor? no matter what car you have there will always be someone with more power and someone who is faster. the rotary is proably an 1986 rx3 so its old as the hills and rotaries ive heard are very expensive to fix. stick with what you have and enjoy it id say
i can't see how they can be A LOT cheaper in mild mod, both need bolt on turbo and other supporting gear, rotor start getting "cheaper" once u do the engine internal as they have far less component
and u are comparing a R33 to a RX3??? OMG....
Try throw a RX3 round the track compared to your skyline... And the rotor loves the fuel, with todays petrol prices its crazy! And I thought the line is crazy on the fuel, well the rotor will chew tones more!
But its down to what you want, sure there quick, power to weight!!! But if your after some comfort and cruising, with power on tap, the skyline is a great car
Hey Rodney, dont worry man its ok, but seriously i understand how you feel, but maybe you just need to learn how to drive first? i mean when was the last time you even hit boost in your car, 2 maybe 3 months ago lol?
Nah man peolpe are right, You can't compare a skyline to an 1974!!!! Rx3, i mean rotars are just straight out quick and skylines are just plain old slow in comparison!
Just kidding, there both top cars, but you should have told me you were thinking of buying a rotar man, i know some sweet rx3's for sale bro.
Cheers Paul
My house mate has a Mazda 1600 Ute with a series 7 RX7 engine, A modified TV51 Truck Turbo.. And it makes 400hp@the rears conservativley, it uses less fuel then my GTR and the whole thing could be built for the price of a r33 skyline... It reliable doesnt burn oil and can be driven daily and beats every road bike that has been up against it.... The only thing it doesnt do so well is go around corners... depends what u want....
Moral of the story.. a Fully built rotor is way cheaper up front and about the same for on going costs.
The same could be said for an old TC/TD/TE Cortina or LJ Torry etc.
250 or 302/308 with a turbo or two bolted on the side of it.
Cheap.
I grew up around rotors, its what initially got me in to the turbo scene.
They use fuel, there is no doubt about that.
NA R33, if your mates rotor is using less fuel than the gtr then something is wrong with the gtr. :huh:
Edited by Cubes
See, I told you so..
The old TE Cortinas weighed in at ~1200kg's.
Kick shiet all over the rotor with a nice little turbs bolted on the side. :P
http://autospeed.drive.com.au/cms/A_2624/article.html
Edited by Cubes
NA R33, if your mates rotor is using less fuel than the gtr then something is wrong with the gtr. :D
Lol, no i think its just the 6000rpm avaiavlable for off boost driving.. so around town its pretty cool, and its to fast to fang everywhere.
On that note, when my skyline was non turbo, i think i had more fun in it, simply because i could give it hell everywhere?? dunno...
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
