...i intend to walk up, with an esky full of beers in on hand.
And an open beer in the other hand at all times  :)
You better keep your sh1t in check, i nominated you the responsible adult charged with getting me and my car home after i have sarked down cans in the afternoon sun ;)
  • Replies 118
yeah .. im in for sure :)
just need to find a driver for my car :O
haha i could allways come with my mum and the L-Plates hahaha... no :|
will be hanging out for this.. any idea of location yet
-Ruffels
It will (should) be crn Alexander Prde and Williams Rd in South Yarra.
Just tying up the lose ends with the public liability insurance for the event before we can 100% confirm it but that should all be cleared up in the next day or so.
Cheers
Well my car may be out of action :rolleyes:, i was going to offer to be your passenger, but i cnbf driving to Eltham just to be a passenger :rolleyes:
you can drive if you want...
just having L's means i cant drive the car without a supervisor lol
just pretty keen on taking my car lol
shouldntbe to hard to source a driver :unsure:
-Ruffels
Edited by Ruffels
shouldntbe to hard to source a driver :rolleyes:
-Ruffels
ill drive it for ya :rolleyes:
get some sleep wob :(
we'll see.. my mates liner will be in at the shop that day so i think he should be sweet to drive me... probably a bit more convient considering hes walking distance from my place
but i'll let you know if it falls through
-Ruffels
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
