  • Replies 294
Sure you can get your wheel back.
When to do it? Ring me on 0421009474.
People who turn up on the day without paying a deposit to me can turn up on the day, but they will have to wait at the bottom of the list.
Edited by gtrGhosTDoGG11
Sounds like a very well matched package.
I've since seen your thread on AUS LS1. Very nice result.
That initial 150rwkw is pretty awesome. What RPM was the dyno run started at? :D
13.2 1/4 was run after the mods?
Edited by Cubes
cheers, ill pay you dyno deposit as well i spose. Oh yeah and have your stock parts to return.
Edited by popeye132
don't think i'll put the corolla on, might break something with all that power, hehe!
Looking forward to it, do we have times yet as i have an engagement party in the arvo and work in the morning but i will definitely be there for sure to check it out!
That initial 150rwkw is pretty awesome. What RPM was the dyno run started at? :P
Yes, run just a couple of weeks ago.
There's more there on the right day.
I was consistently 2 tenths quicker than a guy who has run 13.09 on a T&T prepped track so there's a 12 in her. Hopefully a mid 12 if I can scrape together the funds for a high stall.
Had my white GTR dynoed by Shaun yesterday. He got it up the drive no problem. It ran 249.8 rwkW, 18 kW more than my grey GTR! Now I have to decide which car I should take (unless the white one sells before then).
I'm in.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
